Bearings shot? Plea...
[Closed] Bearings shot? Please help
2 Users
I've a pair of kinesis maxlight wheels, the front one of which has developed some lateral play despite the 15mm skewer being done up tight. I've emailed kinesis directly but had no response. Is the most likely culprit going to be some knackered bearings? If yes, what size do I need to replace then with? Cheers.
Posted : 06/10/2015 5:28 pm
Generally, when you take out the current bearings they'll be stamped with model etc. Then you'll know which ones to purchase...You'll be able tell if it is the bearings because they'll run rough when you spin them in your fingers...(if you haven't heard this already with the wheel freewheeling in its frame)..
Posted : 06/10/2015 5:36 pm
