Bearing seized on p...
[Closed] Bearing seized on pivot bolt - Gah! Help?
4 Users
Tapped a pivot bolt out today to replace the bearings, one of them came out with the bolt and refuses to budge. Any tips for un-seizing the bugger?
Cheers in advance!
BTM
Posted : 28/06/2014 8:30 pm
Heat and a puller ,
Or clamp bearing in a vice and tap the bolt if you get left with the inner race on the bolt .
Repeat with the vice or cut a slot in the race to relive the tension
Posted : 28/06/2014 8:46 pm
Cheers, I'll give it a go tomorrow. Also - any tips on getting the new bearings in square ? I'm using the socket and threaded rod set up!
Posted : 28/06/2014 10:00 pm
Sockets can drop in and damage seals. Try and find cylinders with a flat face before pushing rounded edged sockets in there.
Posted : 28/06/2014 11:40 pm
Dremel is probably the best bet.
I took off the outer race and removed the bearings then cut through the inner race with a plasma cutter and it worked brilliantly!
Posted : 29/06/2014 9:10 am
Blowtorched the bearing, gripped it in a vice and managed to knock the bolt through.
Ended up drifting the new bearings in with mallet and screwdriver in the end as I just couldn't get them to go in square. Terrifying, lots of swearing, but the job is done.
Posted : 29/06/2014 3:13 pm
