Bearing press
[Closed] Bearing press
8 Users
After a year of use the cheap threaded bar I bought to use with some rrp bearing press/extraction kits has worn out
Are there any good (and cheaper) alternatives to the rrp press or do I just need to stump up the cash?
James
Posted : 11/08/2021 2:11 pm
I found BSC after stumping up the cash for RRP's.. bit cheaper, though I can't confirm quality but they look as good as the rrp kit
https://www.ebay.co.uk/str/bicycleservicecentre
Posted : 11/08/2021 2:15 pm
Not pulled the trigger yet but have been eyeing up the cheap ones on eBay for occasional use. Anyone tried them?
Posted : 11/08/2021 2:39 pm
Probably selling the exact same as the eBay stuff but based in Scotland and good customer service and instructions
https://www.bearingprotools.com/
Posted : 11/08/2021 2:45 pm
I’ve got a uk bought bb30 press - think it was Burton Bikes I got that from. Also have a headset press that might be from bearing pro tools. Both work fine.
Recently picked up that cheap Chinese press tool kit above and so far have fitted a bmx bb and full set of bearings in my Bird Aether with it. Works lovely - spins really smoothly and the bearing drifts have fitted nicely.
I’d buy any of them again.
Posted : 11/08/2021 2:54 pm
If I remember right, the RRP use thinner bar than other designs, so they can be used on frame pivot bearings, so be careful if you try to use a different press.
Posted : 11/08/2021 3:36 pm
I went for the Bearing Pro Tools option as above.
https://www.bearingprotools.com/They did a specific kit for my bikes bearing sizes and have worked very well. More beating required than I thought to get the bearings out but more likely down to never having done it in 5 years than the kit itself.
Posted : 11/08/2021 3:56 pm
I bought one of the cheap ones of Amazon. I used it the other day to fit some headset cups. I am impressed for the cost.
Click
Posted : 11/08/2021 4:08 pm
