Bearing installatio...
[Closed] Bearing installation - to grease or not to grease?
10 Users
On the Hope videos, when he puts new bearing in the Pro 3 front hub he puts a smear of grease in the shell to help the bearings slide in. When he does the Pro 2 Evo rear he doesn't. So, grease to help them in, or not?
Posted : 07/09/2016 6:33 am
Greece.
Posted : 07/09/2016 6:36 am
I did yesterday after watching a few vids... i didn't see it doing any harm either way to be honest.
I think people forget that bearings are a service item and not a lifelong item, so getting it back out is important and a little grease may may them stubborn ones just a tiny bit easier.
Posted : 07/09/2016 6:39 am
Cool, grease it is.
Posted : 07/09/2016 6:49 am
Yeah, grease is good. All bearings that are replaced get a thin wipe/brush of the stuff before fitting. No idea if it really helps or not, but cannot do any harm
Carlos
Posted : 07/09/2016 6:55 am
I use copper slip, not grease.
But if I didn't have any copper slip I'd use grease.
Posted : 07/09/2016 7:38 am
BlobOnAStick - Member
+1.
Posted : 07/09/2016 8:09 am
what Blob sez, anti sieze it the one,
Posted : 07/09/2016 8:26 am
Grease or anti seize. Not to help the bearing in but to help prevent corrosion so they are easy to remove when they next need replacing
Posted : 07/09/2016 8:37 am
I have a simple rule for bikes. If I think I might ever want to replace something, I put some grease on it.
Posted : 07/09/2016 8:41 am
They're in. With grease. What a pleasant job servicing Hope hubs is. Most satisfying putting something together with a nylon hammer.
Posted : 07/09/2016 10:28 am
I tend to use a medium strength bearing lock.
it provides anti corrosion like a grease but stops the bearing outer rotating and damaging the hub/frame if the bearing seizes.
Posted : 07/09/2016 10:30 am
