I wasn't paying enough attention replacing bearings on a rocker arm and the bearing went in wonky causing the bearing housing to deform. There's now a groove and matching lip where the bearing took a bite out of the rocker.
Any other suggestions other than file the lip off and be more careful next time?
Posted : 24/02/2020 3:06 pm
File the lip and use bearing retainer if concerned about the groove. Alternatively, plug the area and bore it back out - admittedly this job is a bit more significant
Posted : 24/02/2020 3:08 pm
