I need to replace the bearing for the suspension. the DW link uses 6902 LLU MAX-E-CN.
I can find 6902 LLU MAX-E but not with the CN prefix. I know the "E" means extended , anyone know what "CN" means or where their available to purchase ?
It's internal bearing spacing. CN is standard. C2 less, C3 more, C4 even more. I suppose C2 would be better on a pivot as it isn't rotating fast. Real world- doesn't matter. (ianae...)
If it doesn't say c(whatever number), it is CN.
Look at wych or simply bearing or a n other and see where is cheapest. Wych have been particularly good when I have messed up an order and sent the right bearings out before I returned the wrong ones.
Thanks YAK, that kind of makes sense. So if I order the MAX-E bearings they should be fine ?
Yeah. Make sure it's llu too.
Sorry spacing should be radial clearance. Anyway CN is normal and if not marked is CN. I guess pivot are making sure you don't put a c3 or looser bearing in there.
