So comes with washers.....marked up clearly on pack etc A, B, C, D...
....but A and B swap positions if you turn it over......
any idea what orientation the guidance refers too? Flat bit facing you or bit that goes into the wheel facing you?
Cheers if anyone has a clue 🙂
Can't say I've ever noticed that but I always done bit that goes in the wheel facing me.
You'll know if its wrong because the bolt won't go through
Hmm....kind of hoping to avoid trial and error....
long screw will go in if washer too thin......so only works if washer is too fat......but maybe then it fits-just?
Crappy packaging instructions grinds my gears....quite literally!! 😉
Lift the seals off the bearings and squeeze some grease in before you fit them, otherwise you'll be changing them again after half a dozen wet rides.
