I need to remove the bloody Race Face BB from my YT Jeffsy carbon. BB92 (Ø30mm spindle and Ø41mm shell ID). Can anyone tell me what tools work with this?
[b]X[/b] Race Face puller is generally unavailable or hideously expensive. ParkTool BBT90.3 is for 24mm spindles.
[b]?[/b] Will the ParkTool BBT30.3 do it?
Or the Unior BB30 1625/2? – is the inside diameter big enough?
Other alternatives?
Make your own from a steel tube. I did and saved 30 quid.
Mine came out really easy with a couple of taps with a bit of copper pipe. Replaced with this
[url= http://www.chainreactioncycles.com/hope-pf41-press-fit-30mm-bottom-bracket/rp-prod135904 ]Hope PF41 30mm[/url]
If you're not refitting it, then any old drift will do
If you are not planning on refitting I generally use a Big screwdriver/punch and hammer then just tap around the inside edges. Normally a bit stubborn to start with but once it starts to move comes out pretty quickly. Once you have 1 out the second is a piece of cake
I gently drove mine out on my carbon Jeffsy using a rubber mallet and big screwdriver.
Replaced with the PF41.
Fitting the new BB was the [b]really[/b] hairy bit for me! 😯
Thanks all! Sounds as though a DIY tool is the go. OK here I go.
