BB7 & Shimano P...
[Closed] BB7 & Shimano Post Mount. Friends?
5 Users
BB7 caliper, 203 rotor, Shimano adapter. Post to post
I'm staring at my fork leg, it's staring back.
Caliper/ adapter interface sadness
Posted : 03/02/2014 11:35 am
Are you saying it doesn't work, or asking whether it should?
Posted : 03/02/2014 11:52 am
If there is a problem you probably need some washers, google AVID CPS.
Posted : 03/02/2014 12:04 pm
not sure if this helps
http://www.pinkbike.com/news/tech-tuesday-avid-cable-brake.html
Posted : 03/02/2014 12:05 pm
It doesn't work as far as I see.
Should it work?
Posted : 03/02/2014 12:08 pm
I think you might just need the washer bits like off V brake blocks.
Posted : 03/02/2014 12:17 pm
Longer bolt, extra washer. Fixed.
Now, fitting BB7 to rear of slotty inbred.
Joy
Posted : 03/02/2014 12:24 pm
Shimano use 200mm rotors don't they - would that be the cause of your sorrow?
Posted : 03/02/2014 12:33 pm
cfinnimore - Member
Joy
I didn't have much problem with that... oonce I took a file to the adaptor... and filed alot of the bolt head off... and swapping to a 180 rotor... and filing the wahers plate thingumy... and making a super stumpy allen key...
Simple see?
Posted : 03/02/2014 1:19 pm
Joshvegas it's a sad day.
New 180 rotor, check.
New adapter, check.....
No......wrong adapter.
*sigh*
Posted : 03/02/2014 1:33 pm
Now for the usual faff of figuring out why the new caliper, new pads, new rotor, when all together sound like an angle grinder.
I have deore hydros in a box in the cupboard...talking to me.
Posted : 03/02/2014 2:26 pm
