BB7 Drop Bar Lever ...
[Closed] BB7 Drop Bar Lever Question
4 Users
I have a pair of BB7 MTN callipers and some Tektro levers that are V/non road disc compatible.
I've used this set up previously and they work fine but the set up lacks any barrel adjusters for tuning lever feel.
Any suggestions?
Posted : 11/07/2015 9:00 pm
Buy some in-line adjusters?
Posted : 11/07/2015 9:04 pm
Excuse my ignorance .... Can you get inline brake adjusters or do I just use some gear ones?
Posted : 11/07/2015 9:09 pm
My (roadie) BB7s came with them
Edit: Jagwire do some too
http://www.jejamescycles.co.uk/jagwire-pro-indexed-inline-adjuster-5mm-id87584.html
Posted : 11/07/2015 9:12 pm
 pdw
Mine came with them, but I removed them when I came to replace the cables as they're just not necessary. Clamp the cable so that the arm on the caliper is *just* off the stop, and that's it. You should adjust for pad wear using the adjusters on the caliper, not using the cable.
Posted : 11/07/2015 10:07 pm
pdw - Member
I mainly agree with you, but I still fit an inline adjustment.
This is because no matter how pernickety you are, there usually is a wee bit of bend in the cable around the calliper lever after following your method. (Obviously while trying to eliminate it as much as possible).
The finer adjustment available from a cable adjuster ensures that there is no delay in the movement of the calliper lever caused by the cable straightening before it can move the lever. It's a minor issue but it helps with the feel, and there is less redundant movement of the brake lever.
And 100% as you say, never adjust for brake wear with the cable adjuster, always use the pad adjusters. (The cable adjuster is only used for initial setup.)
Posted : 12/07/2015 6:52 am
