BB30 GXP BB91 head ...
[Closed] BB30 GXP BB91 head ache
3 Users
I have ordered this [url= http://www.merlincycles.com/bike-shop/mtb-parts/transmission-gears/chainsets-mtb/truvativ-aka-chainset-bottom-bracket.html?awc=4456_1376067664_e320592625eff684f6d271e201dfa9ca&source=awUS&utm_source=AffiliateWindow&utm_medium=AffiliateMarketing&utm_campaign=Awin ]Truativ AKA chainset[/url] from merlin cycles as it seamed a bargain and I was hoping to run a bling ring with it.
I wanted to put it in my trek superfly which has a press fit (BB91) bottom bracket.
I have now realised that I ordered a BB30 option (not arrived yet). Would this still fit if I used something like [url= http://www.tweekscycles.com/Product.do?method=view&n=3477&p=394634&c=215&utm_source=Google&utm_medium=Base&utm_campaign=Bottom%20Brackets&gclid=CPe3iobW8LgCFXQftAodxQUAJw ]this?[/url]
Posted : 09/08/2013 5:13 pm
No. that is a gxp bb adapter for Sram gxp cranks.
Your bottom bracket (BB91) uses 24mm spindles.
A BB30 crank will not work with it. They only fit BB30 frames.
Cancel your order or return it.
Posted : 10/08/2013 2:24 am
I think rotor do a BB that will take a 30mm axle in a 24mm pressfit shell. (I'm presuming that BB91 is similar to bb89.5 and bb92, i.e. 41mm inner shell diameter)
According to the below the 4124 should do the trick.
[url= http://www.rotoruk.co.uk/pdfs/RotorUk_StandardDeviation.pdf ]rotor BB compatibility chart[/url]
Never used one though, so not sure how long the bearings will last etc...
Posted : 10/08/2013 6:35 am
Interesting... The 4130 bearings look like they would do the trick. yeah the width (W) across the shell is 98.5 which I guess makes it a bb98.5
It doesn't appear to come with a inner cover though?
I suppose I'll have to check the spindle length as well.
Any idea how these bearing will do with a truvativ gxp crank with regards to the load on the non drive side?
Posted : 10/08/2013 6:21 pm
