Bb spacer help
[Closed] Bb spacer help
2 Users
Hi, I'm just installing a deore bb on a 68mm giant trance x and the instructions show 3 spacers.
The non drive shows one 2.5 spacer and the drive says 2 a spacers (spacer a is labelled 2.5), does this mean I use the 2.5 on the non drive and the 1.8 and 0.7 on the drive as that = 2.5 or does it mean two 2.5 spacers on the drive side?
It only came with one 2.5 spacer by the way.
Posted : 17/02/2013 4:26 pm
For a 68mm bottom bracket fitting a HT2 shimano bottom bracket would need one spacer on non drive side and two on the drive side. All 2.5mm width. You should have 3 spacers all the same width?
Posted : 17/02/2013 5:14 pm
Ignore this all sorted.
