Bb install/spacer q...
[Closed] Bb install/spacer question SLX chainset
4 Users
Installed my new ceramic BB today and am a little confused.
When I was looking, I could have sworn I had 3 spacers installed. However when I installed new one with 3, it was way too wide. So I now have it with one spacer on drive side and none on off side.
I cant find any other spacers on the floor etc so I assume I was being insane and there wasn't actually 3 spacers but only one.
I guess my question is, is only one normal?
Bike is a 2011 Giant xtc2 29er.
Posted : 31/12/2011 9:08 am
Supposed to be on 68mm bb x2 on drive side and x1 on off side, then just x1 on drive side for 73mm but..... If I can - I leave one off to get the cranks on more, I have know more than a few come off which i feel is because they are not on far enough!?
If yours are closing up to the bearing housings (nipped up with hand 'big' torrx -y thing) and are on so the outer clamp bolt is over /close to axle and cranks are clear of chain stays and are reasonably equal on each side - you are good to go.
Posted : 31/12/2011 9:12 am
On my 26ers....
68mm BB shell - 2 spacers drive side & 1 on non drive side
72mm BB shell - only 1 spacer drive side.
not sure if the above also works for 29ers.
Posted : 31/12/2011 9:13 am
All sounds like i'm OK then. Chain alignment is good, spins well in all gears etc.
Posted : 31/12/2011 9:22 am
think the XTC has a 73mm shell so one spacer on the drive side is correct
Posted : 31/12/2011 9:26 am
