BB advice
[Closed] BB advice
3 Users
I have a sram press fit bb 92 and am wondering if will fit my frame which currently has a shimano bb71 fitted? Are they the same size and fitting?
Posted : 12/06/2016 5:54 pm
Yup, also commonly known as PF41 - what happens when marketing people write technical standards
Posted : 12/06/2016 5:59 pm
cheers pal, saves me ordering the shimano one. now the easy part, fitting the bloody thing.
Posted : 12/06/2016 6:09 pm
The cup sizes might be the same, but possibly not the bearings.
GXP SRAM BBs have a smaller ID on the non-drive side bearing.
But if you're fitting a SRAM GXP crankset, you should be OK.
Also worth noting, don't assume the spacer configuration is the same between both BBs. In other words, if your BB71 needed a 2.5mm spacer, that doesn't mean the SRAM BB will need one etc...
Posted : 12/06/2016 10:41 pm
