Not sure if this has been spotted yet
http://www.gizmag.com/cycle-monkey-chain-slap-drive-train/31252/
Crikey hadn't realise chain slap was such a major issue
It's not a looker, is it.
I'm pretty sure a clutch mech would be a far lighter, cheaper and better looking solution.
Pinky, it is available in grey, you know.
Since they're using a rohloff hub, they could simply use a rohloff chain tensioner.
But that's not the ethos with nahbs bikes...
They've eliminated the noise of chain slap by using a Rohloff?
What about the constant "pepper mill" noise coming from the Rohloff?
Or the fact the Rohloff constantly leaks oil on to the disc? Is the non-squealing brake rotors a "designed in feature" or is that a happy accident?
no chain noise is the least interesting bit on that. little or no pedal feedback / chain influence on a high pivot is a quite desirable trait in some circles.
Er, no it doesn't. Not unless you've got an old Rohloff that needs new oil seals, a 10-minute job to sort.
You don't get chain slap if you ride everywhere in a huge gear. Grrrrrrr.
Lot of effort to put Roloff in as rear hub, why they didn't mount it inboard, centrize mass and reduce unspung mass I'm not sure 😉
Lot of effort to Roloff in as rear hub, why they didn't muount it inboard and centrize mass and reduce unspung mass I'm not sure
Yeah this makes no sense - Mount the Alfine where the pivot is if your building the frame from scratch. And if your doing that use a pinion gearbox instead. Both have been done before.
I don't see how this is any improvement on a BB pivot bike
Think an inboard Rohloff would be more reliable than a Pinion from what I seen of them although 'packaging maybe a bit more of an issue
