Fork is an early new shape Pike Select +, probably 2021. It has a Charger 2.1.
Working fine except the compression dial doesn't do much. 20 clicks and feels solid but on my Fox Rhythm is was a short dial that went from open to totally lock the fork.
Broken or is it not supposed to do much, at least statically.
Â
Isn't it supposed to quasi lock the fork at one end?
Â
Thanks
[url= https://i.ibb.co/TqqzHg1G/Screenshot-2025-03-12-11-20-59-621-com-miui-gallery-edit.jp g" target="_blank">https://i.ibb.co/TqqzHg1G/Screenshot-2025-03-12-11-20-59-621-com-miui-gallery-edit.jp g"/> [/img][/url]
Â
I'm pretty sure it isn't meant to lock the fork out, just add more compression stiffness (so a harder hit is needed to make it move).
You can get lockout but it only gives 3 positions - fully open, trail and closed...but you don't have that in the pictures.
