Basic fork compatib...
Basic fork compatibility question (Kinesis Crosslight content)
8 Users
Discovered the ring of death on my Kinesis Crosslight carbon steerer tube and have also managed to strip the threads for the crown mudguard mount, so after a new fork.
I've seen this (link below) on ebay and think it looks good, axle-crown looks the same, steerer is plenty long enough, it's 1.5"-1 1/8" tapered. Is there anything else I'd need to check? This fork has a wider crown at the top by the looks of it, otherwise seems identical.
Then I'd just need a star fangled nut to replace the expander that was in my carbon steerer, or will an expander work in an alloy steerer?
Ebay fork
Posted : 08/09/2025 8:42 am
I would give Upgrade a call. They might be able to sort something out for you.
Posted : 08/09/2025 8:46 am
I have a pretty much brand new selcof full carbon fork off a tempest for sale if that woukd fit?
Posted : 08/09/2025 10:31 am
 PJay
I'm not sure exactly what you're after, but Banana industries have a heavily discounted Fugazzi gravel fork.
https://www.bananaindustries.co.uk/products/fugazzi-gravel-carbon-gravel-fork-with-12mm-maxle
Posted : 08/09/2025 10:40 am
Thanks for replies.
Need post-mount and QRs really or I have to make other changes. Not sure if your Selcof fork fits that bill TP?
Had a look on Upgrade website and all their listed forks are bolt-through and about 3-4 times the cost of the ebay jobbie.
Posted : 08/09/2025 2:42 pm
That video on the other thread showed a steerer repaired by a carbon repair co. May be an option?
Posted : 08/09/2025 2:49 pm
Nope, flat mount with a thru axle apparently
I'm following this thread as I'm after a carbon fork to replace the one on my caadx. However all the fork I can find are 1.25 mm taper, and I need a 1.1/4
Posted : 08/09/2025 3:19 pm
Posted by: tpbiker
I'm following this thread as I'm after a carbon fork to replace the one on my caadx. However all the fork I can find are 1.5 mm taper, and I need a 1.1/4
Posted : 08/09/2025 3:22 pm
Posted by: tpbiker
Canyon use the same fork size iirc.
Got the Ebay fork in the end after Upgrade said they didn't have anything and that they thought it would fit.
Posted : 09/09/2025 1:24 pm
may be too late, but Kinesis/Upgrade recalled a load of Al steerer carbon forks - check you aren't about to buy one of those?
Posted : 09/09/2025 1:31 pm
Oh blimey, well yes I already ordered it so a bit late but thanks for heads up.
I don't have a part number or anything as yet to check it with. The fella at Upgrade did have a look at the ebay fork so hopefully they would have spotted that, but will double check.
Posted : 09/09/2025 2:49 pm
For what it is worth I have two Planet X bikes and one Kinesis. All have the same manufactures sticker on them. Part number the lot. identical.
Posted : 11/09/2025 6:24 pm
Apologies if this is too late but I have one of those forks in my parts bin you can have for free if you want it.
Posted : 12/09/2025 7:52 am
