Bar sweep and angle
[Closed] Bar sweep and angle
5 Users
I currently run a Race Face Evolve Riser Bar with 9° rearward and 6° upward sweep.
I find the bar to be very 'bow' shaped - the sweep means my hands are almost level with the fork steerer tube ( I run a 60mm stem). This makes the riding position feel a little cramped.
Is this normal or am I tilting the bars too far back?
Some people advise to match the sweep with the fork angle, but it seems a bit confusing with these new style 'multidimensional' bars.
Also, about the tilt markings on the front of the bar - I presume that they are meant to be applied against the horizontal, as the stem/head angle will vary across bikes - is this right?
And yes, I know, personal preference plays a major part in all this!
Posted : 18/05/2016 12:26 pm
Why not tilt them forwards a bit, see if you like it better 🙂
Posted : 18/05/2016 12:30 pm
It's a bit of a minefield having both upsweep and backsweep dimensions.
My bars are listed as 0° upsweep, and 10° backsweep. I fit them so that they are rotated forward, to get the sweep at 45° to the horizontal, so that upsweep and backsweep are equal. This means that the manufacturer logos are facing the floor.
Posted : 18/05/2016 12:34 pm
Yes, try it and see.
I always run the combined sweep at about 45°, but others will have different preferences. I don't know if there is an anatomically correct answer - maybe aiming toward you shoulder socket?
I have just done some calcs to get it straight in my head. Assuming a 700mm wide bar with no offset (so that the stem clamp is the centre of the bend - not likely), the combined sweep will be about 10.7° and set at about 34° from horizontal. The end of the bars will be about 55mm behind the centre. If you rotate the bars forward so that the combined sweep is at 45° to horizontal, you will move the end of the bars forward by 8mm, and up by 10mm.
Posted : 18/05/2016 2:51 pm
I've always just left the stem slightly loose, straddled the bike and got the bars where they feel best, then tightened.
Posted : 18/05/2016 3:22 pm
Thanks for the tips everyone.
Rockplough, that's a good suggestion - I will try.
Posted : 19/05/2016 8:52 am
That's what I do. How else would you fit them?
Just rotate until comfy or do the car park test and adjust accordingly. Take an allen key with you.
Posted : 19/05/2016 11:41 am
