Bar mount for Magic...
[Closed] Bar mount for Magicshine
9 Users
 cb
Mate of mine has one of these and the mount is next to useless - the light keeps coming lose and ends up pointing at the floor! Anyone know of a good after market option?
Thanks
Posted : 31/03/2011 9:32 am
try a smaller O ring or pack out the bar with insulation tape
Posted : 31/03/2011 9:36 am
I stuck blu tack under the body of the light.
Crude but effective.
Posted : 31/03/2011 9:41 am
I cable tied mine to the bars
Posted : 31/03/2011 9:44 am
Similar to above - I use a few wraps of self-amalgamating tape to give a soft base for it to bed into and it saves the carbon bars from marking too much
Posted : 31/03/2011 9:46 am
http://www.singletrackworld.com/forum/topic/new-magicshine-with-waterproof-battery#post-1807034
This works great, hense why there out of stock of the mounts on CRC...
(If you can find the Electron EHP300/305/310/315/320/330 mount, it does the same job too, but is no longer stocked by CRC)
Posted : 31/03/2011 10:20 am
Wasnt the other simple solution to hang the light from the bottom of the bar that way it will never end up pointing down...
Posted : 31/03/2011 10:54 am
i use a few wraps of self amalgamating tape on the bar
Posted : 31/03/2011 11:02 am
I use a peice of thick pipe lagging & a big 'O' ring looped around the bar. Works a treat. I got the 'O' rings from a supplier through work. Engineering samples, obviously. 😉
Posted : 31/03/2011 11:16 am
