Baking contaminated...
[Closed] Baking contaminated pads....urban myth?
16 Users
Curious as to wether this works. I recently had problems getting the free stroke dialled when bleeding my XT brakes without the pads in so I carefully (or so I thought) bled them with the pads in situ. Now they're not working as they should so they must be ever so slightly contaminated. I've since bought new pads but was wondering wether the soiled pads could be saved.
Experiences...
Posted : 30/01/2015 6:25 pm
P'raps the BBC should start a new series called the Great British Brake Off.
IGMC
Posted : 30/01/2015 6:28 pm
Stop it...
I'll get mine too...
Posted : 30/01/2015 6:31 pm
Holding contaminated pads over a naked flame (eg gas hob) to burn the oil off can sometimes save pads, but when you can get new pads for a fiver I wouldn't bother.
Simon +1
Posted : 30/01/2015 6:36 pm
Worked for me when i spilled some brake fluid on some hayes pads. Held them over a flame on my cooker for a few seconds. Took it off and let it smoke for a few seconds then repeated a few times. Good as new after that.
Posted : 30/01/2015 7:10 pm
The flame thing makes more sense as the oil gets oxidised to water and co2
The oven thing might evaporate the oil but doesn't seem hot enough to me
But as you've had to ask the question you know it not worth it.
Posted : 30/01/2015 7:14 pm
Stick them in a dishwasher. Extremely hot and caustic.
Posted : 30/01/2015 7:39 pm
Simon..if they weren't the finned ones I'd just bin them.
Posted : 30/01/2015 7:42 pm
I've retrieved a few pads by baking on hot oven for half hour. It does work but only really with light soiling .
Make sure you properly clean the discs too though with brake cleaner and maybe just key the surface with some wet and dry too
Posted : 30/01/2015 7:45 pm
Yes it works!
Electric oven on full whack.
smoky but pads as good as new 😀
Posted : 30/01/2015 8:29 pm
Heated mine over the gas hob. The backing plate fell off 😯
Posted : 30/01/2015 8:33 pm
I've saved pads by putting them in the oven. My housemate was less than impressed by the stink though.
Posted : 30/01/2015 8:56 pm
Dishwashers are nowhere near as hot as an oven or flame.
Posted : 30/01/2015 9:04 pm
yep, oven on max heat for about an hour.
Also done it with a open flame at the midlands XCE champs last year, my calipers were leaking at such a rate that I was having to swap and burn the pads after each round - worked a treat and I was glad each race was only 60 seconds long!
Posted : 30/01/2015 9:05 pm
 Sui
just ride em I'm some mud and drag the brakes down a hill and they'll sort themselves. I've never understood how this can be such a struggle. I've been a cock and contaminated pads a few times, but being a cheap skate I could be arsed to change them.. A few rides and they've always been fine.. Plus it helps your technique aa bit..
Not being able to stop that is...
Posted : 30/01/2015 9:24 pm
Blow torch works wonders, but use it carefully 🙂
Posted : 30/01/2015 9:32 pm
I found baking works better than deep frying .
Posted : 30/01/2015 10:47 pm
Yeah blow torch does work. Or if you're a bit of a pansy like me, creme brulee chef's blowtorch 😆
It gives off a black smoke for a few seconds and then stops - IME this means the oil's burnt off. Controversially I'd rather use the torched pads for a few rides to try and soak up / burn off any oil left on the rotor. Then swap them out for new ones.
Posted : 30/01/2015 11:25 pm
