Axle conundrum?
Axle conundrum?
3 Users
So I have a pair of these on my road bike:
https://www.huntbikewheels.com/products/hunt-48-limitless-ud-carbon-spoke-disc-wheelset?variant=39815114293325
I already had a pair of these, for which I recently added tyres, cassette & rotors to serve as winter wheels:
https://www.merlincycles.com/dt-swiss-g-1800-spline-25-disc-gravel-wheelset-700c-181087.html
Up front, everything is 12 x 100 but the axle on the former won't go through the hub of the latter. From the disc side it stops about 1/2 inch in, and from the opposite side it goes through but stops at the same point. I can't see a ridge, or reason why.
Any ideas?
Thanks
Posted : 28/01/2023 3:41 pm
Hit it harder?
Posted : 28/01/2023 3:59 pm
I'd like to get it out again...
Posted : 28/01/2023 4:01 pm
You didn't mention that 😉🤣
Posted : 28/01/2023 4:03 pm
Sometimes the internal spacers and in my experience, the end caps, can get slightly ovalised during extraction for service - Hope are particularly easy to damage. A bit of wet and dry can rectify this, it only needs to be slight and not perceptible with the human eye!
Hope this helps.
Posted : 28/01/2023 4:43 pm
Yep, turns out that...
Hit it harder?
..was the answer. It just needed a couple of solid taps with the palm of my hand to get past what I think is a small anomaly between hub & end cap. And yes, it slides out nicely - I coated it in parks grease to help.
Thats good, now I don't have a £1500 set of deep carbons exposed to the shitty winter Hertfordshire lanes!
Posted : 29/01/2023 3:36 pm
