Due to the cable routing on my transition tr11 (with saint) the little metal noodle that joins the cable to the mech keeps snapping. Is there a modern similar product to a rollamajig?
Thanks
Paul
I'm not sure if there are any new versions but I think I might have one in the spares box if it's of interest?
Would a Jtek shiftmate zero do the job? Like a shiftmate but with no pull ratio change.
SJS Cycles are the usual internet shop with the stock.
http://www.jtekengineering.com/?&SingleProduct=9
Thanks, will check it out
Its a crud cog hog I have not a rollamajig - still it's there if you're interested.
I doubt I will ever use it again
I still use a cog hog!
Straightens and shortens the cable path and less cable to snag.
