Avid post mount ada...
[Closed] Avid post mount adapter bolts
3 Users
Hi there, could anyone tell me what length bolts I need for an avid post mount cps adapter? As I'm changing the front from 160 to 180mm ? I have managed to get the adapter but I just need the correct size bolts and wondered if I can purchase them quite easily ??
Posted : 22/02/2014 3:38 pm
They're standard metric socket caps. However, if you're talking about a post mount fork,the length varies with adaptor. Offer up the parts to work out the shaft length required.
Posted : 22/02/2014 4:22 pm
While I've never seen it done, I've heard of people cranking overlong bolts in too hard/far and wrecking their forks. As with any bolt, if you start feeling excess resistance back off and work out what's wrong. Not sure if there;s a specific standard depth to the internal PM thread.
I'm sure there's a good resource somewhere but Avid bolt lengths and CPS washers seem to be a bit of a black art. I got caught out with a 185 rotor a while ago. The required CPS washers were a little longer than the 180/160 ones which seem to have the same stack height...
Posted : 22/02/2014 6:57 pm
Cheers guys !
Hopefully my friend is popping around tomorrow with a big box of bolts !!
Hopefully we can find some that fit correctly, as I don't want to over crank and damage my forks !!
Posted : 22/02/2014 8:42 pm
