Avid pad retaining ...
[Closed] Avid pad retaining bolt
6 Users
After one of the bolts that holds the pads in on an old set of elixir brakes.
Can't seem to find any for less than £8 including postage online which seems a bit steep.
Anyone got one lying around or know of a cheap alternative?
<span style="font-size: 0.8rem;">Cheers.</span>
Posted : 02/05/2018 2:05 pm
Have used a split pin from shimano pads before as the avid pins kept splitting.
Try ebay for split pins maybe
Posted : 02/05/2018 2:39 pm
Hadn't thought of that. Good idea. Probably got one of those lying around somewhere too. Cheers.
Posted : 02/05/2018 3:16 pm
I bought a couple of pairs from here
https://www.singletrackbikes.co.uk
Cant find them now, but here is the bit from my email receipt
2      Avid Pad Pin Kit Elixir/Code BlackPair  50524 A15036A      £  11.98
I've learnt that it's always worth putting a bit of grease on the screw and not doing them up too tightly as they do have a tendency to get stuck
But I'd rather that than have to deal with those pesky hair pins when you need to change pads in the wild
Posted : 02/05/2018 3:58 pm
Cheers. That's exactly what happened! Totally stuck and rounded out the heck bolt trying to undo it. Resorted to sawing the top of the bolt and using a screwdriver.
Good point on struggling to get a split pin out on the trail although I don't generally carry spare pads with me so I'd be buggered anyway!
Posted : 02/05/2018 4:08 pm
 aide
Jay, send me an email with your address on. Ive got a spare for an elixir 5 if its the same as yours ill send it down to you
Posted : 02/05/2018 4:17 pm
You're a gent. Thank you very much. Don't think your email's in your profile though!?
Posted : 02/05/2018 6:16 pm
 aide
aideadams46ATyahooDOTcoDOTu<span style="font-size: 0.8rem;">k</span>
Posted : 02/05/2018 8:29 pm
I've got 2 spare split pins and 1 retainingbolt with the little washer. They are for Elixir 1. If you still need them let me know.
Posted : 02/05/2018 8:32 pm
I bin the Avid/SRAM pins. Made of swiss cheese and round off easily if they're stuck. I chuck them and just use split pins. Peanuts for a bag of them from your local DIY shop, easy to use and reliable.
Split pin on the trail, I have a mini tool plyers in my bag. Tiny thing but does the job. A spare split pin or two carried also but usually can reuse them a few times.
My multi-tool allen key is more likely to round off a bolt. Did that once at Afan, then the head snapped off, so had to go into the bike shop to get them to drill it out!
I try to plan brake pad replacement though to not occur mid-ride. Rarely carry pads, but have them in the car with tools.
Posted : 03/05/2018 11:52 am
