Avid juicy bleed pr...
[Closed] Avid juicy bleed problem
4 Users
I've just bled my front brake for the first time and now the lever is hitting the bar. When pumped a little it goes to more normal position when biting.
I followed the avid video on Youtube with that Herc guy in it. I followed it step by step, but have obviously done something wrong!
I degassed the syringes, did everything in the same order and I think I adjusted the lever reach...but I'm not 100% it was enough.
Any ideas?
Cheers 😳
Posted : 06/10/2011 8:31 am
Just try the same again, I had to do mine a couple of times at 1st to get the procedure spot on. Practice makes perfect and all that....
Posted : 06/10/2011 9:57 am
i find it easier to force through a whole load of new fluid tbh then do what that video shows
Just repeat you have air in there somewhere
Posted : 06/10/2011 10:02 am
 JonR
This, and quite a bit of air by the sounds of it.
Posted : 06/10/2011 10:03 am
AHA! It's fixed itself, the pistons hadn't found their place yet and now it's fine. Had the same issue with the back which I did not long ago. Pumped it a fair bit and now it's almost as good as the front (there's a little rub; wonky rotor).
It's probably simpler with new pads as they have less of a gap to adjust to.
Thanks for the advice none the less 😀
Posted : 06/10/2011 6:21 pm
