Avid Juicy 3 needin...
[Closed] Avid Juicy 3 needing bled?
4 Users
 Xan
I have a set of these in my bike, and when I went out last night for a trip round CV I was having problems with my back brake. The lever has all of a sudden went very spongy and now need to press the lever before the brakes work. By the time I got half way round my second lap it felt like I had no back break at all. I am very new to Hydraulics and was wondering if they need bled. I did have to push apart the pads slightly the other night and wonder if I have done this too quickly and put air into the system. Ether that or is there a way to adjust them?
If this is the case I guess the question is where do I get a cheap bleed kit from (this is the cheapest I can find on Google [URL] http://shop.d2leisuregroup.co.uk/product215170265catno0.html [/URL] )
and is there anything I should be careful about. I am assuming that it is easy enough to do. Should I also do both at the same time so the both react similarly?
Posted : 22/04/2009 8:48 am
If you have to pump the lever to get it to work, it sounds like air in the system so it should be bled.
I doubt the air was from pushing your pads back a bit.
I wouldn't call it 'easy' to do. But it is quite a methodical routine. If you follow the instructions, it will work and give good results. Things to watch out for are:
~ contaminating pads with brake fluid - when you attach/detach the syringes small amounts of fluid can leak out. Just make sure you've got a rag to stop it dripping onto pads
~ being too heavy-handed with the syringes - you don't need to really force them. If you do you might squirt fluid past the connectors (or draw air in)
That looks like the cheapest bleed kit on-line.
you might as well do both ends while you've got the kit out.
Posted : 22/04/2009 9:12 am
 Xan
that was teh one thing that was throwing me off was that when I pumped it, it wasnt getting that much better. I have only done about 500 miles since I got the bike and aint particiculary heavy on the brakes. Surely I don't need pads already??
Posted : 22/04/2009 9:16 am
It might be worth checking the pads themselves too. The organic pads that came in my Juicys all wore out pretty quicky.
For info (and others may have other recommendations) I tend to use Avid Sintered, Goodridge Sintered or Superstars Sintered in all my Avid brakes (two and a half sets). They all seem to work well and last well. I save the organics for the Alps.
Posted : 22/04/2009 9:24 am
 Xan
I'll take them out later and have a look. Thanks for that.
Posted : 22/04/2009 9:28 am
 GW
higgo - don't all juicys come with sintered pads? all my avid brakes have (4 sets)
Posted : 22/04/2009 9:43 am
Pretty sure mine all came with organics but I've had them for ages so...
1) they may have changed what they put in them
2) I may have mis-remembered
Also, my Juicy 3 was an OEM one - bargain from Merlin as it had a very short hose (stripped off a bike - presumably the customer wanted a different brake) so they may have put a different pad in OEM c.f. 'normal' sales.
Posted : 22/04/2009 9:48 am
i had similar problems with my juicy threes and i thought it was a problem that needed sorted by bleeding. it turns out that it wasnt. my problems with poor brake performance tend to be a combination of me heating the brakes to buggery by dragging them - thus causing massive amounts of fade halfway through a ride and getting oil on the pads - thus causing a very unnerving my back brake doesnt work situation. because juicys threes tend to be quite spongy anyway both problems feel like a fluid problem.
try this before you bleed the brakes:
clean the disc, either with proper disc brake cleaner or mucoff or whatever to get any contaminants off.
take the pads out and give them a scrub down to get any contaminants off.
refit and go and hare down some hills slamming the brakes on.
hope that brake performance starts to come back.
Posted : 22/04/2009 10:14 am
