Avid Elixir cr
[Closed] Avid Elixir cr
5 Users
Anyone ever tried to replace a lever on these?
Just had a new lever delivered but the wee push rod bit is not transferable from the old lever! As far as I can see.
Can anyone help me, due to head off to the highlands for 2 days next week and would love to fix this as brakes might be useful.
Posted : 02/05/2014 6:11 pm
Pretty sure it is - it's just held in the lever by a plastic gromet type thing - it should just pull out the old one and then put it into the new one
Posted : 02/05/2014 6:58 pm
The only tricky bit is getting the spring back in 😉 but it can be done with patience
Posted : 02/05/2014 6:59 pm
The retaining pivot lever is removable and made of plastic but the push rod actuator is metal and the only way out came out the old lever was by ripping it out. Can't see how I get it into the new one without trying to prise the flanges apart which given its a carbon lever I'm sure will break it.
The regular elixir5-9 have a different design.
Posted : 02/05/2014 7:04 pm
Is there no plastic bushing in the carbon lever for the rod to clip into?
Posted : 02/05/2014 7:42 pm
Is the pushrod like this
http://www.airbomb.com/itemMatrix.asp?ic=1509&eq=&Tp=&MatrixType=2&sGroupCode=PG-251
Posted : 02/05/2014 7:48 pm
Watch this
Posted : 02/05/2014 7:51 pm
Yip! Been through those already, as I said the CR spec is different to the 5-9 versions. Scunnered.
Posted : 02/05/2014 10:47 pm
I have a f+r set of Elixirs taken off a Ghost AMR, only done 200 miles max. Was going to get round to putting them up for sale on here sometime - any use to you?
Posted : 02/05/2014 10:59 pm
Could be tempted but it's a radical solution! My email is britchie7210 at Gmail dot com.
B
Posted : 03/05/2014 3:34 am
Surroundedbyhills - have sent you an email.
Posted : 03/05/2014 1:13 pm
Bullet - no email received!
Posted : 06/05/2014 2:56 pm
What colour CR? I have a barely used one going cheap...
Posted : 06/05/2014 4:19 pm
Sorry mate, don't know what went wrong with the email. Let me know if my Elixir 7's are of any use to you.
Posted : 06/05/2014 10:18 pm
Hi thanks for the offers guys but my tame mechanic got a hold of junk brake for me which cost me a tenner for the workshop beer fund!
Here's what I learned about this:
[*]one very small incident can cost a lot of money to repair and take your bike off the trails for 3 weeks
people are odd on the internet inlcuding STW'ers although none on this thread 😀
manufacuters name things at the cheaper end of the market to bask in the "apparent" glory of their stupidly expensive high end products but in fact they share ZERO components or design
I will most likely buy all shimano from now on, it's cheap, it works and is readily available.
£46 for a replacement brake lever is extortion[*]
Posted : 07/05/2014 10:10 am
