Are these SRAM TL p...
[Closed] Are these SRAM TL pads?
4 Users
They look about right but not listed as being.
[url= https://i.ibb.co/z4fMxyy/A126882-B-C001-43-E3-A798-AB299-C139-B00.pn g" target="_blank">https://i.ibb.co/z4fMxyy/A126882-B-C001-43-E3-A798-AB299-C139-B00.pn g"/> [/img][/url]
Also for a trip to Morzine would you go for Kevlar or organic?
Posted : 18/08/2019 1:23 pm
They look the same as mine op.   I would say I find that the Uber bike pads seem to get through 50 of thier life PDQ then seem to last a bit longer.   I have lightweight rotors which are thinner than SRAM OEM and the “new pad to lots of lever throw” experience can occur over the course of one XC Marathon for me, putting the thought that my pads are vanishing quickly firmly in my head.
Based only on my own experience I’d be nervous about trying those in Morzine, but someone else may be able to provide more confidence.
Posted : 18/08/2019 1:30 pm
If buying uberbike I’ve found race matrix compound the best with Sram guides. I think the backing plates are thinner and the pad material itself is thicker.
Posted : 18/08/2019 2:22 pm
Been using Race Matrix for years on all our bikes both in the UK and in the Alps and never had a problem. Prefer them over the originals that come with the brakes. They also do a semi metalic which is more in line with the pads SRAM come with
https://www.uberbikecomponents.com/search/Sram-level
Posted : 18/08/2019 3:10 pm
Cheers, I picked the right ones then 🙂
The race matrix ones are out of stock unfortunately (although obviously would be best as they're called race).
Turns out it's a mine field if you're looking for advice on what compound to go for.
I wonder if I should just go for organic and get some sintered for of it's wet? Priority is stopping over durability.
Posted : 18/08/2019 4:37 pm
The sintered ones are ok - just a little down on outright power va the race matrix. I think I’ve got sintered ones on the hardtail at the moment and they’re ok.
Posted : 18/08/2019 4:39 pm
It’s the sintered I’m talking about.  Based on the above I might try the race matrix.
Posted : 18/08/2019 4:40 pm
Race matrix back in stock 🙂
Posted : 19/08/2019 11:55 pm
