Are road cassette t...
[Closed] Are road cassette the same as MTB cassette?
4 Users
Got a request from someone in the bike club to help swap a road cassette on their bike. I'm assuming a road cassette (Shimano) is HG the same as MTB and the HG cassette lockring remover will fit the same?
If not, I'm going to look very stupid!
Posted : 24/05/2017 7:48 pm
11 speed no, MTB are narrower, road ones need a proper 11 speed free hub body.
10 speed road are 0.75mm narrower technically, but come with the requisite spacer to sort it out, so non-issue.
7-8-9 speed identical.
Posted : 24/05/2017 7:51 pm
Correct
Posted : 24/05/2017 7:52 pm
Nice one thanks...so my HG remover will work on the road cassette and I can fit the new road cassette on the existing road wheel.
I was asking as I've only ever had MTB kit so I know the HG remover works fine on MTB cassettes.
Posted : 24/05/2017 7:55 pm
Yes, that'll work fine, apologies, assumed you meant you were swapping between road/MTB cassettes. No different tools needed!
Posted : 24/05/2017 7:58 pm
Ideal thanks...I should have made it clearer on my first post.
Posted : 24/05/2017 7:59 pm
If they are different lengths does that mean you can't switch a 10sp freehub for an 11sp one on a road bike? Was wondering about converting my 9sp to 11sp and was thinking it would be possible to switch freehub body and keep same hub
Posted : 24/05/2017 8:23 pm
Depends on the hub. Most of the big brands do 11 speed freehub bodies, they're only 2.5mm wider, so still fit in ok.
Posted : 24/05/2017 8:47 pm
Cheers njee. stans hub and saw a conversion kit (i think) but was then wondering if it would fit frame but 2.5mm not much difference!
Posted : 25/05/2017 9:12 am
