Hard to tell from the website [url= https://www.panaracer.com/lineup/gravel.html ]here[/url]
The tubeless versions appear only to be the 40mm versions. Likewise Evens say that the ones they have in stock aren't the tubeless versions. Is there a new model out or something?
The info is confusing but yes they are. Got them on my crosser and they're great.
Good stuff. Do yours have 'TLC' on the side? The ones at evans dont which suggests to me that they may have some old ones in stock which means I'll order online instead.
Unless ofcourse yours also dont but are tubeless anyways, in which case I may take th epunt on them being the newer versions
Not that I can see, no. I think they are 'guaranteed' TLC up to 60psi, which is about as hard as you'd want to run them anyway. Mine are good at about 45.
Haven't used SKs but the slicks have been fine tubeless at up to 80psi in 32 & 28c versions.
I have the file pattern Gravel kings, not the more nobly Gravel kings, in 32c running tubeless if that helps.
