Are all cup n cone ...
[Closed] Are all cup n cone axles made equal?
6 Users
I've been having on going issues with the rear axle of my Longitude and as of this morning the axle bolt itself is somewhat buggered. The hub is a Joytech RCC 6-Bolt 135x9mm QR and the main axle bolt needs replacing. However I'm struggling to find info on whether a Weldtite one on Evans will be suitable. If anyone can shed any light on this I'd be very grateful.
Mat.
https://www.evanscycles.com/weldtite-hollow-quick-release-axle-10x145mm-00101706?esvt=52800-GOUKE2009952&esvq=&esvadt=999999-0-1145506-1&esvcrea=166214592157&esvplace=&esvd=m&esvo=00101706-D-NA&esvaid=50080&gclid=CPKUiMfuoNICFQEM0wodsv8CMA
Posted : 21/02/2017 9:35 am
Evening bump
Posted : 21/02/2017 5:31 pm
Should be fine. The thread pitch and size will be identical. You used to be able to get titanium ones to save a bit of weight...
Forgot to say the cones may be a bit soft, so if you can get Shimano ones that fit I'd use those instead.
Posted : 21/02/2017 6:03 pm
Schmiken +1
I've used generic axles in bikes before and they always had issues, either the bearings wore rapidly, or axles bent.
I presume shimano must use a better grade of steel in their axles, likewise the cones.
If you can figure out the equivalent shimano parts it may be worth making a note of the part numbers and seeing if an LBS can order them from Madison to upgrade the hub.
Posted : 21/02/2017 6:15 pm
I used to run solid axles with nuts on XT hubs a years back. The same company used to make proper chromoly QR axles as well but I can't remember who does them-however you certainly won't find them at Evans. You need decent 4130 rolled thread.
Posted : 21/02/2017 6:21 pm
https://www.sjscycles.co.uk/wheel-axles-qr-nutted/
Wheels manufactureing
Posted : 21/02/2017 6:23 pm
Thank you all I'll speak to sjs. I'd certainly prefer a shimano one for peace of mind.
Posted : 21/02/2017 8:07 pm
 JoeG
[url= http://wheelsmfg.com/products/hub-parts/all-axles.html. ]http://wheelsmfg.com/products/hub-parts/all-axles.html[/url]
[url= http://wheelsmfg.com/products/hub-parts/all-cones.html ]http://wheelsmfg.com/products/hub-parts/all-cones.html[/url]
Posted : 21/02/2017 11:40 pm
Sometimes it's cheaper to buy a full Shimano hub to use for spares.
Posted : 22/02/2017 7:21 am
