Arch EX or Grail ri...
[Closed] Arch EX or Grail rims for CX
11 Users
I'm building some new wheels for the crosser and the iron crosses I had my mind set on are now gone so am left with grails (or iron cross at normal price) but have spotted some arch ex which weigh the same and are 1mm wider, any reason not to? Max pressures don't seem to be an issue
EDIT: Or is there anything else I should be looking at?
Posted : 16/01/2016 10:09 am
Alpha 400?
Use them on my Singular & they've been bombproof.
Posted : 16/01/2016 10:21 am
Did look at those but heard bad things about them and tubeless cx tyres, plus can't get them as cheap
Posted : 16/01/2016 10:34 am
 cp
I use WTB frequency i19, which work great. CRC have them
Posted : 16/01/2016 10:58 am
 jonk
If you want to run road tyres get the grail, if not crest, arch and iron cross.
Grails popular amongst my CX mates.
Race & Offroad sportive Gravel stuff..
Posted : 16/01/2016 11:00 am
I was looking at those WTBs as well, cheap with BC discount and the lightest option, apart from spending twice as much on Iron Cross to save 20g.
How about Crests?
I'll be running cx tyres only on these, tubeless as I'll be selling the road bike and getting a separate set of wheels for road tyres on the crosser
Posted : 16/01/2016 11:10 am
How about Crests?
I run a set of Hope Hoops Crest 29ers on mine set up with tubeless cross tyres from 33 up to 38 depending on the tyre and they've been great with good tyre profiles. I suspect all the Stan's options will do the job just fine.
Posted : 16/01/2016 11:15 am
I had crests but now have grails they feel nicer tbh
Posted : 16/01/2016 11:48 am
In what way do they feel 'nicer'? Just wondering. The Crests feel fine to me, but I don't have any direct comparison for perspective. Quicker? More supple? More precise? Better tyre profile?
Posted : 16/01/2016 12:05 pm
They feel stiffer and the tyre profile is better. The crests didn't feel bad it just feels different with the grails. Certainly feel a better rim for the tyres I'm using
Posted : 16/01/2016 12:09 pm
What CX tyres are working on Crests for you chaps? (Tubeless)
Posted : 16/01/2016 12:19 pm
So the internal width difference of 0.7mm gives a noticeable different tyre profile, 20.3mm on the Grail versus 21mm on the Crest? I hadn't realised that such a small difference could have such an obvious impact. Interesting... what tyres are you using btw?
Posted : 16/01/2016 12:24 pm
I've run both TR and non-TR versions of the Bontrager CX0 (sort of semi-slickish) - from 33 to 38 - tubeless on Crests and the WTB Cross Boss, which I think is TR by default, on the same rims. All work well for me.
Posted : 16/01/2016 12:26 pm
It does strangely enough but maybe it's the 35mm and 32mm tyres I'm using. Or perhaps due to the rim wall height it's on optical illusion but the bit that physically holds the Bead on is a different size, shape and profile iirc. They are defo stiffer
Posted : 16/01/2016 12:38 pm
Ta, BWD. Have some awful wire Contis at the moment that sit crooked and are impossible to fit or remove.
Posted : 16/01/2016 12:40 pm
I've been using arch ex rims on my cx for several years now with no issues. I've used 33 and 35mm tyres. Max pressure ice done is 60 which is over the 55 stated max. It's worth noting that I only managed that pressure with stans cx tyres. Others blew off by 55 (messy!).
I usually run 40-45psi which seems about right for off road cx (rather than cx racing). I'm pretty heavy though
Posted : 16/01/2016 1:15 pm
What are the Grails like if you wanted to use 25/28s on them?
Posted : 16/01/2016 1:28 pm
I've not tried tbh
Posted : 16/01/2016 1:42 pm
Currently using Spesh Terra Pro and have previously used Vittoria XG Pro TNT. Both have worked very well but prefer the Terra.
Posted : 16/01/2016 2:07 pm
