App to record bike ...
App to record bike settings?
10 Users
2 Reactions
Is there a bike specific app to record things like tyre pressures, shock pressure, rebound settings etc?
I know I could just write this down on paper, but I'd like something on my phone so I make notes when I'm out.
I could just use OneNote or something similar, but just thought that someone must have made an app for this already
Posted : 27/05/2023 11:07 am
How about knocking up a spreadsheet in Google Sheets, and saving a link to it on your homescreen.
You can make it as simple or complex as you want it to be.
Posted : 27/05/2023 11:19 am
thols2 reacted
I made a spreadsheet and was going to keep it updated witha sheet for each of our bikes and add extra stuff to it etc etc
I got this far and never bothered, but if you’re a bit more dedicated than me it’s easy enough.
Posted : 27/05/2023 12:12 pm
I use Google Docs.
Have a document detailing shock settings, but also then listing every item bought and fitted.
The beauty of this over a spreadsheet is that I can have unlimited notes and comments.
Can access from my phone on the trail but also at home on my laptop.
Started it back in Feb 2011 when I bought a new single-speed Hope back wheel.
Posted : 27/05/2023 12:47 pm
phil5556 reacted
The shockwiz app probably covers most settings you want and has a notes field too. Don't need an actual shockwiz to use that part.
(download it and check out the 'profiles' tab)
Posted : 27/05/2023 12:57 pm
I use a google docs spreadsheet.
Suspension: tokens, pressure, rebound, compression.
Tyre pressures
Saddle: height, fore/aft, angle
Stem spacers
Handlebar roll
Grip roll
Brake, shifter, and dropper levers: distances from grip, angle
Brake reach adjustment
Bar light angle
Posted : 27/05/2023 1:06 pm
I’ve got a white board in my workshop to record all sorts of random stuff, cable outer length among other shit.
Posted : 27/05/2023 1:44 pm
Sagly lets you record shock/fork settings, tyre pressures, etc. and gives you pointers what to do if, e.g. you find yourself bottoming out your fork
Posted : 27/05/2023 1:56 pm
There’s one called MyBikeSetup on Android
Posted : 27/05/2023 2:18 pm
Couldn't find the app in the Play store.
Don't know why I never thought of a whiteboard, that would be handy although I'm not sure I've got any spare wall space.
The risk of using a spreadsheet is that it turns into a coding exercise as I get carried away!
Posted : 27/05/2023 8:29 pm
Word or whatever the Google Doc version is and just write it down...there are many things that don't really need an app to allow you to do things - this is an excellent example of just that.
Pen and paper would be ideal, but if you don't want to physically write then open up a text document on your phone and type.
Spreadsheet could allow nicer formatting in the sense of columns and rows so everything is neat and tidy but just write it down as that is all it needs.
Posted : 27/05/2023 9:02 pm
