Anyone with Rohloff...
[Closed] Anyone with Rohloff and Gates belt drive experience
3 Users
Has anyone got real world Rohloff and Gates belt drive experience and could you please help me out?
In the new year I'm looking into buying a new 29er+ bike frame which is capable of fitting a Rohloff hub with a gates belt drive and I'm rubbish at maths.
When reading through the Gates website from page 38
my brain has melted.
I want to run the 29er+ for bivi riding in the hills, so low gearing is important but looking here http://www.carbondrivesystems.com/products/cdxsprockets at the pulley/cog sizes here I can't work out which would be the best Rolhoff set up for a 29er+ wheel diameter.
There are only 3 sizes of Gates CDX rear sprockets for the Rolhoff hub a 19, 20 and 22 tooth/pulley rear sprockets.
So, what size would I need up front to help with climbing on the bigger wheels?
Also with an EBB what size chain ring could I go up to on the front as an option if I wanted to fit it for faster flatter rides but using the same belt and rear pulley?
Thanks you all you mtb maths experts.
Posted : 22/12/2013 5:28 pm
Gearing is a very personal thing - what's a low gear for one person might be too high for another. If you want to play with gear ratios, I have free software:
http://www.kinetics-online.co.uk/parts-accessories/gearing/k-gear-software/
Best thing to do, especially if your mind doesn't work in gear inches is to put in your existing gear ratios to start with, to work out what you have - then you can play about with the Gates sprockets.
Posted : 22/12/2013 5:34 pm
And having a quick play with the ratios I have on my Rohloff (44/16 on 26"), if you have a 29er with a 50t on the front, a 20 or even a 22 would be about right - 22 would give you lower gears of course.
Posted : 22/12/2013 5:37 pm
Silly question time.....
Does a Gates chain ring size equate to the size of a normal chain ring?
i.e. the front rings seem quite big, does a 50 tooth Gate ring mean the same as a 50 tooth conventional ring?
Posted : 22/12/2013 5:50 pm
What frame are you considering, sounds very interesting?
Remember a 29+ wheel has quite a bit bigger circumference than a 29er wheel so as previously suggested working out gear inches and comparing to what you currently find comfortable would be a good indicator of what to go for.
Posted : 22/12/2013 5:59 pm
No. But what matters is the ratio of front cog to back cog, so as long as you compare the ratios you're fine.
Posted : 22/12/2013 6:05 pm
bencooper - Member
Cheers Ben but what do I need to add into that great gear calculator
I've just worked out that a 50 (TOOTH) x 20 (TOOTH) would be a fraction lower at each end at my standard 3 x 9 combo.
But if you say that the Tooth to Pulley ratio isn't the same what do I put in there for the belt drive to give me the same on a 794mm diameter wheel?
My 3 x 9 is 44-32-22 with a 32 x 11 on the back with a 740mm wheel diameter.
Posted : 22/12/2013 6:23 pm
If you're using my gear calculator, then just bung the Gates pulley size in both. So 50x20 sounds right for you too, giving similar ratios to the setup I have.
The only thing you can't do is say "a 44t chainwheel works for me, so a 44t Gates pulley will give the same gearing".
Posted : 22/12/2013 6:35 pm
Looking at the frame I'm after the biggest Gates Pulley is a 46 in size.
Does anyone know what standard cog tooth size this would be the same as to help with the calculations on Ben's calculator?
Posted : 22/12/2013 7:29 pm
Just bung in 46 as the chainwheel size. Then the size you pick at the back will be the rear pulley size.
Posted : 22/12/2013 7:51 pm
