If so so did you fit the barrel adjuster?
Where did you mount the lever? any pics etc.
Ta.
I didn't fit the lever as it's on my XC HT.... only place I could fit it would be central next to the stem.
Never bother with barrel adjusters either (on any droppers)... or supplied cables, I buy good quality lined outer by the 10m and PTFE cheaper inners in 10's....
I stick it in... leave long enough to grab with pliers and let it stretch (still workls just looser)....then pull it through and cut off the end and recrimp...
Cheers Steve, just wondered if anyone had used it on a drop bar bike.
I like the idea of tucking it under the LHS brake lever so I can thumb it. Just not sure that's going to work.
Link for the curious
https://www.chainreactioncycles.com/brand-x-ascend-cx-85mm-105mm-dropper-seatpost/rp-prod159175
I might have to try one of these...
