Anyone seen a 32mm ...
[Closed] Anyone seen a 32mm turnkey or moco damper out there?
3 Users
Looking for a replacement 32mm rockshox damper
Anyone seen any crown operated ones? Or got one swapped out?
Posted : 03/09/2020 11:49 am
Actually for an xc30 steel stanchioned fork
Posted : 03/09/2020 12:33 pm
One came up in my ebay the other day... I din't look in detail as I'm not looking for one.
Posted : 03/09/2020 12:42 pm
@stevextc
I ordered a replacement but the threads are 1mm to narrow to fit and no interference in the stanchion as it goes in. I assumed any 30mm tk damper would fit a 30mm tk fork?
Posted : 03/09/2020 12:44 pm
I got a 2014/15 ish straight steerer/QR air TK something 26" sat in the shed you could have...but can't see it being economical to get to you... ??
I might have a SID MOCO top I could check fit and got a set of same vintage 32mm Rev's that I could service and have a look if it helps? Bit of a pain to do right now and I'd have assumed a 32mm MOCO is a 32mm MOCO ... and perhaps just the top cap changed?
Posted : 03/09/2020 1:13 pm
It's a tk damper from a silver xc30 not 32mm
Gold damper for 30mm stanchion doesn't fit
Posted : 03/09/2020 9:15 pm
silver are steel stanchions, gold alloy IIRC so the wall thickness will be differnt thus the internal diameter different even if the external diameter is the same. Not sure but I think so
Posted : 03/09/2020 9:57 pm
@tjagain
You are right I assume the gold stanchions are thicker looking at the damper. But you'd assume that the top cap threads would be the same?
@stevextc tk 30mm silver fork?
Posted : 04/09/2020 8:56 am
@bikerevivesheffield
I'd need to look... it was taken off a used bike before it was ridden. Steel stanchions and air spring... I'll get the serial and stick it in ... you're welcome to it if you can arrange collection but might be barely worth it. I only kept it in case it was ever useful to someone.
Posted : 04/09/2020 9:06 am
Only need the damper please
Posted : 04/09/2020 9:18 am
Check this .. happy to remove and send the damper if it's the right one and you need it.
XC30 TK
FS-XC30-TK-A3 - 38t45509341
SERIAL NO 38T45509341
PART NO 004018708005
MODEL ID FS-XC30-TK-A3
MODEL NAME XC30 TK
WHEEL SIZE 26"
TRAVEL 100MM
STEERER 1-1/8" ALUMINUM
AXLE
9MM QUICK RELEASE
DAMPER TYPE N/A
VOLUME REDUCER
N/A
DAMPER ADJUST
CROWN
SPRING
SOLO AIR
SPRING RATE
N/A
COLOR
DIFFUSION BLACK
FORK OFFSET
40MM
MIN ROTOR SIZE
N/A
Posted : 04/09/2020 2:26 pm
@stevextc WhatsApped you
Posted : 04/09/2020 6:15 pm
