Anyone running eagle with an 11 speed chainring? Just bought the kit without the cranks and chainring from bike discount de. Any issues running it with an 11 speed chainring or does anyone do a 12 speed chainring that fits raceface direct mount cranks?
Running One Up Switch sram direct mount. The rings say 9 10 11 and 12sp compatible and all good with Eagle GX so far.
FSA 11spd n/w chainring on gx eagle. Its a bit noisy when in 36/42/50 and putting the power down.
Mine is running on the same Works ring that I had 10 and 11 speed on, it's grand.
Inner chain width is the same as 11 speed so any chainring will work with it. That said imo the eagle chainring is superb, that fancy hooked design retains the chain better than any other design and wear levels are reduced compared to other n/w rings i've used before.
Inner chain width is the same as 11 speed so any chainring will work with it. That said imo the eagle chainring is superb, that fancy hooked design retains the chain better than any other design and wear levels are reduced compared to other n/w rings i’ve used before.
Is is there any way to get an eagle chainring on a raceface crank though?
I like the look of that! Might go with that option.
