Anyone running a Mi...
[Closed] Anyone running a Middleburn Uno with Rohloff
3 Users
A consideration as the 38t rings are available, but the question is what bottom bracket axle lenth do you use to get the chainline (54.5 IIRC)?
I've emailed and spoke to Mat at Middleburn, it's just not easy getting that info from him, seems fairly non committal.
Posted : 22/01/2010 10:39 am
Woodsman did you ever get an answer this?
I'm about to try an uno rohloff setup and would quite like to minimise faffing time.
Posted : 05/03/2011 4:40 pm
113mm with the ring in the outer position & 121mm in the middle.
Posted : 05/03/2011 4:48 pm
