Anyone know how to ...
[Closed] Anyone know how to remove a straitline vertical wedge stem?
2 Users
Got a really annoying clicking noise in my headset/stem area and so wanted to take it apart, check it all and put back together, but can I get the f******g stem off? I've seen somewhere that you should remove both bolts and then screw one back in the middle hole but that doesn't seem to be helping?
Posted : 23/01/2010 5:32 pm
Both bolts out and one in the centre hole is what you do! Takes a fair bit of welly to break the clamping force. Give it a couple more turns...
Posted : 23/01/2010 5:36 pm
Just keep tightening it up?
Posted : 23/01/2010 5:38 pm
yip...
obviously use judgement and if it seems really seized then maybe you need to resort to WD40 and big hammers...
Posted : 23/01/2010 5:41 pm
Ok cheers, I'll give it a go. The stem's only a couple of months old so it shouldn't be too bad. I was probably just worried about breaking it before.
Posted : 23/01/2010 5:43 pm
Thanks again for your help - gave it some welly and the problem was solved. Clicking noise all gone as well!
Posted : 23/01/2010 6:09 pm
Cool - glad to be of some help. I've seen my buddy struggle to straighten his bars after a crash so many times I was pretty sure a bit of brute would sort it out :o)
Posted : 23/01/2010 6:14 pm
