Anyone got quiet Sr...
[Closed] Anyone got quiet Sram Guide brakes?
12 Users
In the soaked conditions we have now?
Sintered pads (original SRAM).
I thought my original Hope Minis were bad, but it's got to the point where I'm actually reluctant to brake because of it!
Is there anything I can do?
Posted : 07/01/2016 5:37 pm
Which rotors do you have, the original ones were a lot noisier than the later centerline versions.
Posted : 07/01/2016 5:56 pm
Yes, centerline rotors, Uberbike sintered pads.
Posted : 07/01/2016 6:41 pm
First 2 pulls after being soaked then quiet after that. No braking surely means faster and more skill?
Posted : 07/01/2016 7:02 pm
Same, noisy at first but quieter after they heat up a bit.
Posted : 07/01/2016 7:05 pm
Mine are just noisy all the time !!
Posted : 07/01/2016 7:28 pm
Try realigning calipers, try some different pads?
Posted : 07/01/2016 7:30 pm
Nice and quiet. Uberbike sintered pads, Shimano rotors.
Posted : 07/01/2016 7:37 pm
Yep. A pair of Guide Rs and a pair of RSCs, both currently running sintered Superstar pads (previous history with these pads are normally noisy).
Posted : 07/01/2016 9:28 pm
hmmm - good that some of you have achieved quietness. Mine used to just be on the first couple of pulls, but is now on anywhere wet.
I have some Uber sintereds to try next. Maybe I'll change early.
2015 Centreline rotors btw.
I've tried realigning the callipers, but only using the 'loosen-clampbrakes-tighten' method.
Posted : 08/01/2016 11:24 am
Cleaned your rotors? Do this before changing pads.
Posted : 08/01/2016 11:34 am
Make sure you bed the pads in properly, as i found the brakes noisy until this was done.
Posted : 08/01/2016 11:35 am
Same, bed the pads in.
Having said that, RSC's with centerline rotors, they still squeal in the current weather conditions.
But they are a lot better than the old juicy's.
Small price to pay for such good brakes.
Not even sure you can get organic pads for them?
Posted : 08/01/2016 11:38 am
The pads are the same as the Avid Trails and I tend to prefer the Superstar Kevlar pads, quiet and plenty of stopping power.
Posted : 08/01/2016 12:11 pm
 mboy
Centreline rotors and OEM pads here... Noisy in the wet (what brake isn't), but nowhere near as noisy as some I've ridden, but only for a moment until the water has cleared. Nice and quiet otherwise, and overall, been very impressed with the brakes, especially the modulation compared to the Shimano XT they replaced.
Posted : 08/01/2016 12:21 pm
ta - I'm going to swap the pads, clean the rotos, bed the pads in (which I do anyway), and then check alignment. Hopefully all combined will bring me silence.
Never had a peep out of my previous Mono Minis.
Posted : 08/01/2016 12:55 pm
