Just ordered one which (I hope) will arrive in a couple of weeks.
Are the internal cables easy to route? As if they’re a pain, I’ll get the LBS to do it.
Is the supplied frame protecting ‘clear coat’ stuck in the right places? Sufficient? As I’m considering a wrap if not.
Any idea on QR seat post collar size?
Ta
Hi Lardman, good choice 🙂
Internal cables were pretty easy - can't remember if there are 'channel's inside the frame but it defo wasn't a massive pain. The grommets to stop the rattles are a bit undersized. My mate drilled them out a bit to fit. Only ended up putting one on dropper cable and had no rattles from any of the cables.
The routing is a bit meh tho as it comes out of the middle of the frame. Defo add more protection there as it rubs the down-tube. Also watch out for mech cable routing round the shock. Mine was rubbing the X2 can so I added more protection there.
Aside from that tho, the supplied protection kit is good. Which is defo a good thing as the paint is rubbish 😉 Mine took a battering on the Basque trip. If I'd fitted a bash guard before, I probably would have got away without any major paint loss. Also with 2.6 tyre in the back, I've added a bit to the inside of the chain stays.
31.6 for dropper. I ended up running a PNW 200mm as I couldn't fit a 210.
Awesome bikes, only thing I'm not that happy with is the X2. Hence considering a coil.
@Alex
Thanks for the response. Good to know about the routing etc. I’ve ordered the feni. Coil frame, as I’m (clearly) a bit of a chunker and coil is always king.
Did you mean a downtube bash guard?
I’m not overly fussed about frame chips/scratches as I I’m rider not a re-seller. But, nice to know about flaky paint job!
Nice green colour there…. I wish they did the Fenix coil in other colours too. Mines black (which is ok) but a little boring.
Chain Guard. I didn't fit one and the 'lug' under the BB took a heck of a battering.
