And out of the frame, with a ruler nearby?
Looking to get a grub screw barrel bolt/solderless nipple for the stealth actuator on the bottom of the post itself. On the way home.
Can anyone tell me the diameter of the little cup/ nipple holder, please?
Thanks!
Posted : 03/12/2019 3:25 pm
Slightly smaller than a brake cable end.
I just used a gear cable and ztto lever, hooked the end into the holder and its worked fine so far just a bit more fiddly to install.
If you do find a source let me know.
Posted : 03/12/2019 3:41 pm
Needs a 6mm barrel thingy with the grub screw inside
Posted : 03/12/2019 4:30 pm
