Anyone else stuck i...
[Closed] Anyone else stuck in the 26" and obsolete standards 'rut'?
50 Users
Starting to realise that having a 26" framed, full suss bike that only takes a straight steerer sucks. It's a Commencal Meta 55 and is a great bike.
It does have issues though, the first is weight. It's great going down but can be a bit slog climbing. I'd like a slacker head angle too for steeper stuff. The rear suspension is super plush but completely lifeless. I've not been able to find a balance between smoothing out the bumps and keeping the rear poppy enough..... plus am I not allowed to want something new? 🙂
The problem is that everything has come to the end of the line. To move on the wheels, forks and frame* all have to be ditched.
Which points to the next problem, how do I stop myself ending up in this situation again? Boost 29" seems the safest bet.
*A short term fix could be to switch frame but finding a second hand frame in 26" I'd be happy spending money on might be tricky, i.e. most are going to be well ridden/used by now. Might go for something like an Orange 5 that's fairly bombproof
Posted : 03/02/2017 2:17 pm
You can stick 26" wheels in a 650B frame without dying. I've done it with my Flare although I just swapped everything over including the 26" straight steerer forks so only had to buy a new (tapered-to-straight) headset. It's 'future proof' insofar as it can take 650B wheels if I [i]really[/i] need it to but I've got loads of good 26" spares so hopefully won't have to cos, well, I love small wheels.
The 142x12 rear is probably quite safe although I wouldn't bet the house on it 😆
It is ok to want a new bike though!
edit- I don't see it so much of a rut as a (stubborn?) choice to stick with stuff that still works and I enjoy.
Posted : 03/02/2017 2:23 pm
26 isn't dead.
Get a new shock.
Or a >2016 Banshee Spitfire/Rune (if you can't convert your current hubs, you can get QR dropouts). Seen plenty '13-'14 Spitfire frames for around £650.
Posted : 03/02/2017 2:24 pm
It is an advantage for wheels. You can pick up some great bargains, often for less than the price of the hubs. Just a bit tricky to get wider rims. Still plenty of good frames out there for cheap albeit with older geometry. It is harder to get good forks though. Not dead by a long way
Posted : 03/02/2017 2:28 pm
Yup. Being behind the curve means much cheapness in secondhand parts. Other folks upgraditis means my bagainacious spares supply.
Posted : 03/02/2017 2:30 pm
A Banshee Spitfire is an option I've previously considered, might look at those again.... Hubs are Hope Pro 2 Evo (135mm rear?) I think the rear might be convertible to 142mm.
Posted : 03/02/2017 2:32 pm
I had a straighter steerer Nicolai with 26" wheels. Likewise decided wanted something slacker. I picked up a second hand Spitfire from here, and a set of 27.5" Pikes (when buying stuff from Europe was cheap!) and transferred the rest over (including Hope Pro 2s - would have to check what size - the OH does the technical stuff!). Went with the larger fork so it was future proof should 26" wheels come hard to find, but in the meantime all our bikes run 26" so it seemed daft to not have the spares etc. Just means I have decent mud clearance and can make the whole thing 27.5" as an when, if I need.
Also, it rides like a ***** - absolutely love that bike!
Posted : 03/02/2017 2:37 pm
whatever size wheels you have they all move forwards and they will all see you to the bottom of the drop with a great big grin. Take the cheapest option.
Posted : 03/02/2017 2:52 pm
Yes true. Wheel size is actually the least of my concerns, it's much more the obsoletion of everything else caused, directly or indirectly, by the change in wheel size.
Posted : 03/02/2017 3:01 pm
I have a Five that has all the 'old standards' but is still a superb bike. Rather than flap about a new one, I got a cheap Boardman FS Pro that is my workhorse which will mean the death (due to lack of straight steerer forks) on the Five will be delayed....
Posted : 03/02/2017 3:26 pm
My old 26er susser had a straight steerer, 135mm QR rear axle etc. Ended up getting a used frame (still a 26er, but a relatively modern one) and everything apart from the shock (different stroke) was moved over: Hope hubs meant I just had to switch endcaps to go 142x12, the fork could be travel extended, and a crown reducer meant I could put the straight steerer fork into a tapered headset. Very happpy, and I'm now on the prowl for some cheap Arch Ex 26er rims to give the bike some on-trend wide rims...
Posted : 03/02/2017 3:35 pm
the only real problem is a lack of decent straight steerer forks
Wont be "advancing" to 650 b as i dont believe it make a jot of difference
I suggest of you swapped everyone wheels over to 26 ers none of the owners would notice and you can achieve the same wheel size with a massive tyre anyway
If I did mile munching rides - i do but use my road bike or the CX bike- i would probably have a 29 er hardtail
Not getting rid of my 26 ers till I cannot buy forks
Posted : 03/02/2017 3:40 pm
Yes it's the forks that have driven the change; nowt wrong with 26".....
Posted : 03/02/2017 3:44 pm
Thanks, cheered me up a bit!
I think I have a plan forward, a Banshee Spitfire in 26" mode. Then when it comes to replace or upgrade the fork* I'll go to 27.5", but only then..... unless there are some super cheap 26" fork deals about!
*It's Fox and the short service intervals are frustrating... time to learn to do it myself
Posted : 03/02/2017 3:48 pm
I've been recently hankering after a mountain bike again after a few years off. There's my 575 in bits which I'd like to build up 1x and some modern rims but I'm unlikely to get my head around the various permutations of what will and won't fit, and it'll cost a fair bit just to replace the rear suspension bearings, service the forks and shock - so the old 3x9 stuff looks a lot more likely at this point!
Posted : 03/02/2017 3:49 pm
You need to try to find some of the last-gen Solo Air Lyriks with a straight steerer and add a Charger Damper.
I run my Spitfire 26", with 26" drop outs and a 27.5" Pike up front. It hasn't killed me. Yet.
Posted : 03/02/2017 3:50 pm
 poah
I replaced my old ghost last year with a transition suppressor frame because I couldn't afford to go 27.5 (wheels and fork plus frame) swapped everything over which was nice. I did buy a stealth reverb though. They may even have a couple of medium's at the importer. I also considered the spitfire and rune before I got the suppressor.
Posted : 03/02/2017 3:52 pm
Suntour Epicon (32mm XC/trail sort of stuff) or Durolux (35mm, bit heavier duty) are both still available in 26" straight steerer. X-Fusion do a couple as well I think.
My DH bike is still 26". No reason to change for the foreseeable. Been the best bike I've ever owned by far.
Posted : 03/02/2017 3:56 pm
I've bought a Capra and have just bought a secondhand Shan frame to stick all my obsolete bits on
Posted : 03/02/2017 4:00 pm
The last 12 months have seen me throw my all in with 26 inch, still running 9 speed.
Firstly a brand new Stanton frame which in the end only cost £280 - how much are they now!
Then came a £100 9 year old Epic frame which I built into a lovely summer 25lb xc machine with existing parts.
And finally spend £230 sticking the new lyrik charger damper in my 2014 air lyriks. All this is on top of a 2013 Meta AM frame
Posted : 03/02/2017 4:02 pm
[quote=kayla1 ]Suntour Epicon (32mm XC/trail sort of stuff) or Durolux (35mm, bit heavier duty) are both still available in 26" straight steerer. X-Fusion do a couple as well I think.
not exactly what you would spec on a new bike though are they
Essentially the industry wants us to replace whole bikes rather than upgrade parts
If we dont play along we will return to standards rather than always have moving standards as all they actually care about is profit
Posted : 03/02/2017 4:03 pm
 Sui
seconded teethgrinder - i run my Spitty 26 with 27.5 pikes on. my wheels are also new, i just don't like the new size..
Posted : 03/02/2017 4:04 pm
As with any old bike you have to decide if you are comfortable with spending cash to keep it alive knowing that it could be money to a newer and better bike. Some point you may want to make the jump. Newer bikes will be much better than what you have. Bikes have certainly come on a lot (controversial view on this forum) since your bike was new!
I wouldn't waste money on anything substantial like frames/forks anyway unless its second hand and far better than what you have.
Posted : 03/02/2017 4:08 pm
I think it's straight steerer head tubes and straight steerer forks that have become difficult to source.
At the moment if your 26 inch frame takes a tapered fork there are plenty 2nd hand available and they're still serviceable and in the expensive category Pike and Fox 36s are available for 2017 for 26 inch tapered. It's just will many folk actually fork out for one of them on their 26er now? Sadly I expect not but it's great to know that they can be bought brand new still and I hope they're still available new for 2018/9.
I wouldn't want to be on a non boost 650B frame right now either - I'd be massively hacked off. I don't think there will be many non boost new 650B forks in a year or two so you may need a new hub on your front wheel if you did break your non boost fork. There's a lot more non boost 29er year models so that wouldn't be so bad but I suspect boost 29er forks will be the future soon.
It'd been nice if they'd moved to 650B and boost hubs at the same time.
I think when they make a big change like wheels lots of people hold back with new purchases and watch to see if they'll change things again and so hold on for longer with what they've got. Once you see a settling down of standards it's worth investing. I am hoping boost hubs is that settlement for wheels for a few years now.
My bikes are 2013 and 2014 model year 26ers. Both tapered head tubes. Both ride superbly.
I'm trying not to upgrade anything that can't be moved to the next bike now but I've more or less decided to keep going for another year on them because they're great bikes. I'd have switched them out a lot sooner had the route out been a bit less spendy. At least I'll have had my money's worth out of them.
I think safe bets are boost 29ers right now.
I'd like to hope boost 650b was a safe bet too but I expect not.
Posted : 03/02/2017 4:16 pm
Junkyard- Dunno, there's nowt wrong with the Suntours other than they're not badge enough to match Audis/T5s in the car park.
Posted : 03/02/2017 4:36 pm
my current bike is a 09 Giant Reign X2.
170mm travel with offset bushes so the front end is a very slack 64.5 degrees. it weighs about 35lb with the tubeless AM wheels but more with the DH wheels
climbing can be a bit of a slog especially on really steep stuff where the front end really does wander but going downhill on it is a hoot.
however its time for a new bike and if things go to plan i will have a new Reign by the end of tomorrow.
i'm still keeping the old one though...i've spent too much on it to want to sell it for a massive loss...what i'll do though is get a lighter hardtail frame and transfer all the parts to it and give it to my son.
26" isnt quite dead yet
Posted : 03/02/2017 5:00 pm
All my bikes are still 26" - no desire to change them any time soon
I've got three fully built and one in bits
In fact I've just pretty much finished building up a new (to me) 2013 Transition Covert 😀
Posted : 03/02/2017 5:20 pm
 core
@kayla1
How are you finding that Flare on 26" bits? BB ridiculously low? I really want one, but with the price of the frame would really need to swap all my bits over and 'upgrade' to 650b over time.
Demo booked up at FoD on Sunday......
Posted : 03/02/2017 6:50 pm
I bought a 2013 used once round the car park Granite Chief last year for peanuts and rebuilt it with all my blue parts, should do me till all this nonsense blows over...
Bought a Dune too but that's 26".
Posted : 03/02/2017 7:49 pm
All 6 mtb's in our household are 26", but did invest in tapered headtube frames for the most recent purchases, will be servicing the forks frequently & running them to the death, to be honest a 29er hardtail would make sense but can't be arsed to change now
Posted : 03/02/2017 8:05 pm
I run four 26 inch MTBs. A rigid scandal, old Marin for commuting, a 456 for Winter duties and bikepacking. I also built up a new prophet after the BB thread stripped on my old one. Its got bolt through forks, a dropper post, its 1x10, i have a large frame so its long with a short stem and wide bars. I can't see any reason to change, it can go down anything i'm prepared to go down, it does have the advantage of having a 1.5 headtube so can take tapered forks.
The bikes all work for their intended purpose, I reckon I can keep them going for a long while yet. I've got a spare set of Revs for the 456 which would probably be the hardest part to replace.
Posted : 03/02/2017 9:09 pm
I have this problem with my Patriot. However I mentioned it to Mojo, and they said that if/when my 66s finally die beyond repair to speak to them. They thought they could knock something up with a straight steerer.
So give them a bell if you get stuck. And can afford new Fox forks...
Posted : 03/02/2017 11:55 pm
@core- it's fine, really. I've got my (26") forks at 150mm to make up for the difference in fork length and the Flare can go to 140mm on 650Bs. Nowt's a bother. The BB drop's only 13.5mm with 130mm 650B forks according to the Cotic website. Cotic should advertise the Flare and Rocket as 26 or 650B though, not just 650B I reckon, what with the whole '26" ain't dead' thing.
It's handy knowing that if we do eventually run out of 26" wheel spares I can fit 650B if I absolutely have to but I'm in no rush at all to move to bigger wheels, and when my lovely straight steerer forks finally shuffle off I'll be able to swan off and buy some tapered steerer jobbies to replace them. It's the switch to tapered that's buggered most people up.
Posted : 04/02/2017 5:25 am
Fattie and HT both 26" Happy 😀
Posted : 04/02/2017 6:04 am
It's the wheels and tyres thing that bothers me. I've got 2 or 3 pairs of Hope/Flow wheels and a good selection of quality tyres.
Posted : 04/02/2017 7:12 am
 core
I'd have to go 140mm 26" fork in a Flare, which would drop BB more than yours kayla, but then I'd only run 130mm in 650b mode I think......
The thing that gets me is boost, it just isn't necessary for non-plus I don't think, such marginal gains, which most people won't feel. I'd be mighty pee'd off if I got new 650b wheels and forks now in 15x100 and 12x142 then when I need another fork it's only available in boost, so necessitates a new front wheel, again.
Better to stick to all the soon to be obsolete standards
on 26" I reckon, wait for things to settle down then go 650b/boost all in one go.
Manufacturers must find it a ballache, from 5 years ago basically just making different travel/spec. forks in 26" with perhaps 2 axle options to now having to potentially do that in 3 wheel sizes, with 2 different hub widths as well, though besides DH everyone seems to have settled on 15mm axles up front now.
But perhaps everyone constantly 'upgrading' is making it worthwhile?
Posted : 04/02/2017 7:51 am
...boost, it just isn't necessary for non-plus I don't think, such marginal gains, which most people won't feel...
A boost rear hub is 6mm wider than a 'standard' 135/142.
If increasing the flange spacing by 6mm doesn't do much, then [i]reducing[/i] the flange spacing by 5mm would do even less.
130mm roadie dropouts anyone? Think of the heal clearance!
Posted : 04/02/2017 8:33 am
There's an argument to be made that Boost isn't actually necessary for plus tyres either...
Ultimately all the re-baselined standards shenanigans will have two probable effects, for serial bike changers it will probably push up the decision to buy a new dandyhorse, for many others it's going to put them off buying a bike for a bit longer, in the hope that it all settles down a bit...
Bikes are (for the most part) depreciating assets anyway, but yep tweener wheels and a hundred possible axle/BB/headtube combinations have made buying a new MTB a trying experience...
Posted : 04/02/2017 9:13 am
Three bikes in the house - all 26", straight steerer, threaded BB, QR rear, two are 20mm front, the last is QR. Been holding off doing anything til things looked like settling down a bit - now got a Boost 650b, tapered frame on order. Still got a threaded BB though!
Posted : 04/02/2017 10:53 am
I think we are just moving closer & closer to the automotive model of parts being specific to make, model & year, not too long you'll need to go to shop and ask for a hub for a 2023 giant anthem
Posted : 04/02/2017 11:49 am
Forks are a pain.
I'll probably just get a rigid carbon when the Reba finally wears out.
If I needed a new bike, a rigid 29'er appeals.
Surly Karate Monkey looks fun and pretty future proof.
Next pointless standard?
I'm going for flat mount MTB brakes.
Posted : 04/02/2017 12:01 pm
I ditched a few older 26ers and bought a 2016 rigid 29er. Thing is apart from the wheel-size it's all still old MTB standards. I'm hoping not to hit too many problems during my remaining time.
Posted : 04/02/2017 12:04 pm
a pair of practically unused deemax ultimates, and a brand new pair of crossmax ST,
God knows how many partially used tyres, a box of least twenty unused inner tubes
And then I made the mistake of looking in the spare parts drawer:
[img] https://s29.postimg.org/h83gd1pon/IMG_1165.jp g" target="_blank">https://s29.postimg.org/h83gd1pon/IMG_1165.jp g"/> [/img]
Posted : 04/02/2017 12:07 pm
Crossed post MR!
What did you end up with?
Still all 26" here and I've been trying to by a new bike for a few years now but every year I seem to spend the bike-fund on biking trips abroad 🙂
Oh the shame as everyone points and giggles at my wheenie-wheeled bike being loaded on the helibiking cradle!
I'm happy with my bike.
I'd only replace it if it got stolen.
Love to try an old full susser, something like a Prophet or 5, but the fork thing puts me off.
But if I 'invested' in the secondhand Soda I've always fancied, a rigid fork means it should be useable for years.
Obsolete or not.
Posted : 04/02/2017 12:14 pm
teethgrinder - Member
Or leave it with the damper it has, which I prefer (if it's the Mission Control). Charger is nice in my Pikes but I feel it's a downgrade on a Lyrik. Less controls and not so plush.
Anyway, some straight steerer frames can still take tapered I believe depending on the head tube or using some adapters (might raise the height of the front I guess).
Other than that, I'm in a mix between 26 and 27.5 at the moment between a few bikes, but still mostly 26 and not intending to replace them. They're nice bikes.
I've even just bought new 26 wheels. It's getting hard to do now, especially new and anything other than Hope laced to Stans rims (neither of which I wanted).
Sadly justridingalong have dropped custom builds of anything but their own brand and Industry Nine, so that's one respected online custom builder who did 26 gone. Just tried Ptcycles though and good selection of 26 still, and wheels turned up quickly, all look good.
Posted : 04/02/2017 12:33 pm
Prophet has a 1.5" headtube so you can use 1 1/8" straight, tapered or 1.5 straight steerer forks.
Posted : 04/02/2017 1:06 pm
Thanks!
I might keep a look out for one.
They always looked like a really well thought out, fun, well balanced bike.
Posted : 04/02/2017 2:17 pm
With wheels, just learn to build yourself. I picked up a new (but older model) 135 rear XT hub and qr for £45 not so long ago. Plenty of choice of 26 rims on CRC from Spank, WTB, Stans etc.
Posted : 04/02/2017 5:49 pm
If anybody needs a pair of 15mm front, 142 rear wheels I have a used once set of XT's in 26"
Posted : 04/02/2017 6:54 pm
I could furnish you with a modern 26" Commencal Hip Hop. Slack tapered etc.
;0)
Posted : 04/02/2017 7:09 pm
 br
I went 29 FS last year as I'd broken my 26 carbon FS and couldn't find a decent replacement (in large/XL). Still got my 26 HT (456Ti) but rode it the other week and tbh it's not a patch on the 29 FS on local trails.
Got two pairs of late model Revs in straight-steerer, so the HT is fine and a tapered Pike which no doubt I'll be selling.
Posted : 04/02/2017 7:13 pm
Both my mtb's are 26 hardtail.
One feeds the other, spares wise and I have a couple of pairs of forks for the good one. The other is a slop bike ,and when all the forks dry up they'll go rigid. Most my riding these days is darn sarf and suspension forks aren't really necessary. I even have a 3x9 as its so cheap!
Tbh if I needed a full suss I'd change to 27.5, but there's more chance of my next bike being another cx gnarpoon.
Btw Hello br.
Posted : 04/02/2017 7:54 pm
clubby - Member
Yeah, I'm thinking that's the way to go. One of the last things on a bike I can't do myself anyway.
It's still a bit voodoo magic to me though.
Posted : 04/02/2017 9:36 pm
I'm slightly in this boat - 26" bike with a pretty old school set of angles etc
Blew the fork damper last summer and was genuinely wondering if that was enough to make me buy a new whole bike, rather than throwing cash at an "obsolete" bike
The on-one selloff of SRAM spares may have saved me there, though it'll be another month before I have the free time to see if my new £12 unit fits
However, if a manufacturer made a decent FS frame with swappable droputs that'd allow different hub spacings and wheel diameters I'd quite likely bite anyway. Nice oversized head tube with offset reducers to allow varying reach or head angle would be another incentive to do so
My 26" stuff wouldn't go to waste in the end either - 3 ladies in my family who don't ride much but all have 26" bikes
Oh, and wheelbuilding ? Piece of piss if you follow instructions. Genuinely easy IMO
Posted : 04/02/2017 9:57 pm
Building your own wheels is brill. I built a set of wheels up with wide 26" rims last year and did a couple of races on them and didn't die- very satisfying! I need to re-do the rear because the hub can't be converted to 142x12 and I want to try some of those WTB 26 plus tyres on the Flare.
Posted : 05/02/2017 10:05 am
It's interesting reading this thread, I don't seem to be the only one mulling a rigid 29er over at some point in the not too distant future...
I was eyeing up the 2017 Longitude on fresh goods Friday; QR/euro-BB/straight steerer (B+ or 29), all seems good to me and framesets seem to be around the £400 mark online...
26 ain't dead yet, but I reckon a fair number of the 26ers still in service have probably got a DNR against them now... And 29er marked as a potential replacement...
Posted : 05/02/2017 10:16 am
Does the new Hope bike use something like this?
Exactly what my other half intends to do. Should be fine. 140mm 26" forks in a Flare that is.
I think the WTB 26+ are too big to fit the Flare (and most 650b frames).
Forks are a pain
You can still get [b]new[/b] Pikes, 36s and Lyriks in 26"
And plenty of budget options if you don't want great forks.
You can even get straight steerer if you look hard enough.
I think, just like front axles going from 20x110 to 15x100, we just have to accept it is happening, and ignore whether it actually needs to happen.
Posted : 05/02/2017 11:30 am
kelvin - Member
You can still get new Pikes, 36s and Lyriks in 26"
New Lyriks are 650b and 29er only.
However you can get the charger damper to retrofit an old 26 Lyrik, and you can probably still find plenty places selling the old version.
Out of interest, or probably not, old 26 Lyriks with the 20mm axle turns out to be boost width (110mm). I hadn't realised that despite owning one.
Posted : 05/02/2017 12:17 pm
Crossed post MR!
Took a look at a Longitude then ended up with a Vagabond. Still have a 26er utility bike (Dutch) but it's a essentially a heavy Nexus-equipped Dutch bike and so far maintenance-free (except for a drop of oil) bike so parts not a problem as yet.
Posted : 05/02/2017 12:30 pm
You can buy 26" Lyriks "new", but they aren't the latest version, true enough.
Posted : 05/02/2017 12:35 pm
I accept it's happening (already basically happened hasn't it) but I reserve the right to bitch and moan about the need for it for a while yet 😉
TBH if ever there was a case to resuscitate single crown, USD, 20x110 axled forks it's to accommodate B+/29/29+ tyres...
Posted : 05/02/2017 12:51 pm
Both my bikes are 26" - HT and FS.
Both capable of taking tapered steerer forks too.
There'd be no problem with running 650b forks if you can't get 26.
I think tyres are going to be the problem further down the line.
Posted : 06/02/2017 5:09 pm
Bit the bullet and bought a 2017 Banshee Spitfire frame 😀
Thoroughly recommend the frame and Pedals in Bruntsfield, Edinburgh
Posted : 22/04/2017 12:59 pm
The only issue is straight steerers. You can put a 650 fork on and run 26" wheels (I do this on my Zesty) but getting straight steerer forks is getting tricky. Considering the steerer is just interference push fit into the crown of the fork, then getting a "straight" adapter turned up for a tapered fork ought not to be impossible (obs you will loose a bit of the stiffness of the taper type design)
Posted : 22/04/2017 1:09 pm
Good call on the Spitfire.
Modern geometry & standards, but still great with 26 inch wheels.
Posted : 22/04/2017 1:17 pm
Pointless post... Deleted
Posted : 22/04/2017 5:13 pm
@maxtorque not sure what you mean?
Posted : 22/04/2017 5:49 pm
I've got a 26" 2011 5. Still by far a better bike than I'll ever be a rider (I'm well overbiked on it)
3 x 10 on it too. I'm not very good at fashion either.
Posted : 22/04/2017 9:37 pm
Yes and still loving it 8)
Posted : 22/04/2017 9:41 pm
As above I have an Orange Five 3x10 26er with a straight steerer and its pretty good not amazing but pretty good ,it was built up and finding the right bits was pretty easy although getting a straight steerer fork is getting increasingly harder.
Posted : 22/04/2017 9:50 pm
2014 Blur Tr bought second hand from the classifieds for £600 last year. 140mm x fusion slant up front and a set of Chris King/Mavic wheels I picked up for £250 a few years ago. An equivalent bike today would cost far more than I would be willing to pay. I reckon there'll be enough 26 kit knocking about fir the next few years to keep me going.
Posted : 22/04/2017 10:06 pm
Just replaced my Kona Heihei with a Trek superfly, £275 for wheels and frame s/h, and about the same on bloody adapters and widgets to make stuff fit.
My god that Heihei frame is light though. If anyone wants an incredibly light short travel FS 26 race frame and forks, let me know.
Posted : 22/04/2017 10:18 pm
I'm all in on 26", I have 3...the jump bike/4x bike is the only one with a straight steerer but also worth very little so not worth selling, also 26" is best for that type of bike IMO.
I bought them my other two bikes (2013 models) for a great price in 2014 just as 27.5 was starting to take off.
I love them and have no concerns, you'll be able to get 26" rims for some time, maybe not the latest and greatest (although I see Stans have included 26" in their new line up) but as for forks you can just run 27.5 forks just increases their A2C by 10mm.
If I wanted to go out and replace my to trail bikes (Ti HT & FS) to an equivalent spec brand new I reckon I'd be looking at about £8-£9k...how much better would they be...negligible!
Saying all that my mates ride 27.5 but I'm quicker so I have to wait for them anyway
Posted : 23/04/2017 7:03 am
Molgrips - I am interested - gies a message on facebook old chap
Posted : 23/04/2017 7:12 am
Did anyone go to see the Howard street dual in Sheffield city centre the other week?
The bike that was ridden to 4th place and was narrowly beaten in the small final by peaty had:
26" wheels
Straight steerer in a straight head tube
27.2 seat tube
135 qr back end
So I reckon that sort of bike will do for me.
Just had the bearings in my blur 4x changed. Frame bought secondhand 3 years ago. Cost peanuts. If I'd bought a current frame at the time it would be out of date now anyway as everything seems to be boost now. No point trying to keep up.
Posted : 23/04/2017 7:26 am
