Any updates- Mixing...
[Closed] Any updates- Mixing 11 speed Shimano/Campy road and 10 speed mtb mechs?
6 Users
Has anyone managed to run shimano 11 speed sit drop bar shifters with 10 speed rear mechs on an 11 speed cassette?
Anyone done this with Campy Shifters?
Posted : 20/03/2015 2:48 pm
Forget about using Dura-Ace 7900 derailleurs with 11-speed levers. The derailleur’s shift-activation ratio is different for Shimano 11-speed rear derailleurs than it is for Shimano 10-speed rear derailleurs. Furthermore, Shimano 10-speed mountain and road rear derailleurs have different actuation ratios from each other, and the same goes for Shimano 11-speed mountain and road rear derailleurs. Prior to road 11-speed and mountain 10-speed, things were simpler; Shimano road rear derailleurs up through 10-speed and mountain-bike rear derailleurs through 9-speed all have the same activation ratio.
And your intuition is correct that a Shimano 11-speed shifter will not work well with a 10-speed front derailleur because the 11-speed shifter is designed to actuate the longer lever arm of Shimano 11-speed front derailleurs
Read more at http://velonews.competitor.com/2015/03/bikes-and-tech/technical-faq/technical-faq-10-11-speed-drivetrain-component-compatibility_362722#QeGMA2Hqdr7lwlsg.99
Posted : 20/03/2015 2:58 pm
All I want is a clutch rear mech for 11s Shimano road sti.
Posted : 20/03/2015 3:09 pm
You and a lot of cyclocross riders.
Posted : 20/03/2015 3:16 pm
 D0NK
shimano are going to run out of actuation ratios soon and will accidentally create a 13 speed system that will work with 6 spd road mech and a 7 spd mtb mech
and yeah the tourers will rejoice
Posted : 20/03/2015 4:03 pm
Dirty rider Im not so sure about your post as I'm running Ultegra 6800 shifters with a 5700 front mech without issues?
Posted : 20/03/2015 8:17 pm
