Any tips for mounti...
[Closed] Any tips for mounting a very loose tyre?
7 Users
I have couple of fatbike tyres to fit. They are very loose on the rim. The result is that on both sides of the tyre the bead is sitting quite a way onto the rim at one point on the circumference, whilst elsewhere it is popping off.
I know I could lube up the bead, but I'm worried it will be more likely to pop off.
Am I best to bulk out the rim bed with some foam?
Posted : 09/05/2018 7:33 pm
Lots of turns of tape, or change of tyres.
Posted : 09/05/2018 8:23 pm
What tyre and rim combo?  Some play together better than others. Are you using On One rims perchance?
Posted : 09/05/2018 8:36 pm
Yes. And Vee Bulldozer 4.7 tyres.
Posted : 09/05/2018 8:38 pm
I had a similar issue with a bmx tyre back in the day. Solved it with a strip of cardboard and sticky tape. Worked surprisingly well.
Posted : 09/05/2018 8:45 pm
Tried the tyre lever trick to lift the bead up onto the rim before inflating?
Posted : 09/05/2018 8:59 pm
Please enlighten me regarding the tyre lever trick...
Posted : 09/05/2018 9:30 pm
I carry about "10" shoe laces for mounting floaters back on the rims, very light and does the trick, get funny looks mind but works.
Posted : 09/05/2018 10:35 pm
I have mounted the front with using silicon lube, a compressor, 40psi, and a lot of holding-my-nerve. I'll need to let my bravery reserves re-build before I tackle the rear.
The front is now sitting at 20psi to mellow overnight.
Posted : 09/05/2018 11:13 pm
I'd change tyres. If it rolls off its a horror show.
Posted : 09/05/2018 11:43 pm
If it rolls off, it "might" be a new tube, and it "might" be a wonky seat on the rim until I can sort it.
Posted : 10/05/2018 1:30 am
This morning it was evident that last night's antics had pushed the tube too far.  I put 3 wraps of 1mm foam around the rim bed, covered it in tape, and it worked perfectly.
Posted : 10/05/2018 11:11 am
