Any older Rockshox ...
[Closed] Any older Rockshox experts about?
13 Users
I picked these forks up cheap (being obsolete 26" and 20mm). Ride really nice, very smooth. Just trying to work out what they are and what year. Right leg has compression at the top, rebound on the bottom, left has +ve air on the top. Bulges on the lowers.
[url= https://i.ibb.co/9Ggqwmq/IMG-20200410-125218.jp g" target="_blank">https://i.ibb.co/9Ggqwmq/IMG-20200410-125218.jp g"/> [/img][/url]
[url= https://i.ibb.co/y5tC1YQ/IMG-20200410-125239.jp g" target="_blank">https://i.ibb.co/y5tC1YQ/IMG-20200410-125239.jp g"/> [/img][/url]
Posted : 10/04/2020 1:13 pm
I think you can enter the serial number from the fork into the SRAM website and get info on the forks.
Posted : 10/04/2020 1:21 pm
Rob votes 2010 SIDs
What does Rob win if Rob is correct?
Posted : 10/04/2020 1:35 pm
Doubt they're SIDs if they're 20mm, so guessing Revelation.
Posted : 10/04/2020 1:44 pm
I'd say Revelations with the bolt-through. Maybe 2010-2012ish?
Posted : 10/04/2020 1:55 pm
Older serial numbers dont work on trailhead.
Serial number on the back of the crown will give the production week and year.
Posted : 10/04/2020 2:37 pm
id say Revs. Go on the RS website for the serial number thing. I had a set of badly re-painted forks on a jump bike i was kinda given which needed a service. Put SN in the RS website and ordered the seals which it recommend, they were the wrong ones...just saying.
Posted : 10/04/2020 2:48 pm
Doubt they’re SIDs if they’re 20mm, so guessing Revelation.
Dammit! Should have looked closer.
Posted : 10/04/2020 2:53 pm
I'd go with 08 or 09 Lyrik RC
Posted : 10/04/2020 2:56 pm
I'd agree, lyrik most likely as they look like 150-160mm travel, though more like 2006 with that crown
Posted : 10/04/2020 5:31 pm
They look very much like a set of revs I have but not identical
Lots of good info on the rockshok site but some of it a bit hard to fine
Posted : 10/04/2020 6:03 pm
 nuke
RS Domain going by their look and the damper unit adjuster...not sure on stanchions as OPs look better than standard Domain so maybe Lyrik
Posted : 10/04/2020 6:15 pm
I had a rev about that time and it doesn't look like it. I'll go Lyric from around 2013.
Posted : 10/04/2020 7:35 pm
Stanchions printed 160mm, with power bulge I’d go lyrik. Post the serial number on the back of the crown to get the exact year.
Post mounted, straight steerer, air, I’d say 2010 model.
Posted : 10/04/2020 7:47 pm
Serial number is 18t30375572
Seem to be Lyrik RC. Not sure of age.
Posted : 10/04/2020 7:59 pm
The number after the t is the last digit of the year of manufacture. In your case 2013.
Posted : 10/04/2020 8:25 pm
