Any deals about for...
[Closed] Any deals about for 100mm 29er forks?
4 Users
Anyone seen anything? Checked the obvious online stores and the German sites but nothing stands out. Or maybe forks are just big money these days.
<span style="font-size: 0.8rem;">Looking for tapered with bolt through axle, non boost. Recon/Reba would be fine.</span>
Ta
Posted : 09/10/2018 7:03 pm
 a11y
http://www.chainreactioncycles.com/mobile/rockshox-rs1-acs-solo-air-forks-2016/rp-prod136311
Although “A "predictive Steering" hub is also required for use with these forks, due to the toothed dropouts”
Posted : 09/10/2018 7:17 pm
Cheers, anyone seen anything else?
Posted : 10/10/2018 1:38 pm
Second hand? I have a set of Rebas here, set at 120 but can be dropped to 100. Nice long steerer still and 15mm maxle. I have them looked open as the bar mounted lock-out is useless so I took it off. Could be converted to a fork mounted lock out or use as is.  Otherwise all in good condition with just normal marks from use, paint rub from mudguards etc. Can do photos if interested. <span style="font-size: 0.8rem;">Could do them for £100 plus postage</span>
Posted : 10/10/2018 2:08 pm
Have just ordered these for £277  :  http://www.chainreactioncycles.com/fr/en/rockshox-sid-rl-solo-air-forks-boost-2017/rp-prod174786
But 29" version is only selectable for the "list of options", so not sure if they are actually in stock.. will find out in a couple of days!
(they're boost, but I'll buy a conversion kit for the wheel if they actually turn up)
Posted : 10/10/2018 3:45 pm
Thanks all, sorted now!
Posted : 10/10/2018 7:26 pm
