Had the frame for a few months but I hadn't finished the build as I was waiting for the forks to come from America.
[img]<img [/img]src="http://farm6.staticflickr.com/5477/12031974906_eb9d5dcc59_c.jpg" width="800" height="600" alt="Untitled">
It needs some new pedals & I'm on the look out for a silver Thomson stem & post to finish it off, but what do you think?
That's nice (other than the fork looking a bit tall). Good clean lines, looks like it should skip across rooty singletrack.
Thank you fasthaggis, what did I do wrong?
No worries ,I like an nice uncluttered build 🙂
You just needed to paste this line^^ in to the image box.
Looks like you could get away with bigger comfort tyres in the Summer 😉
I know what your saying about the forks, they are 453mm, I should of gone for the 440's, but even then there would still be a big gap 🙁
Maybe I'll see if some 700c wheels with cross tyres fit, I used to run my Ti Pipedream that way & it even made an article on a different forum as it was niche back then 😉
How is that chain tensioned?
Its not, it needs a slightly worn chain otherwise it is a bit tight, but I guess if it gets to slack then I'll just put a new chain on another bike & use the old one off of that 😉
