another long shot.....
[Closed] another long shot.. fitting a Di2 EW-RS910 control box to a flat bar
2 Users
I have one of these:
https://www.merlincycles.com/shimano-di2-ew-rs910-e-tube-bar-plug-mount-103348.html
plug
which normal fits in the end of a drop bar. I want to use it on a flat bar with MTB grips.
Has anyone done this? The plastic 'wing' mounts (right of pic) mean that fitting a grip/lockon over it is, well, impossible unless I trim away the inside of the grip, which is gonna be tricky.
I could try and fit it without the 'wing' mounts but it's not obvious how it would stay put then... mmm any ideas?
I've not found a compatible grip yet, and I doubt I will.
Posted : 03/02/2020 4:28 pm
It can be done.
There was someone, possibly on MTBR or Weight Weenies, who fitted one in the and of a flat bar. I think he needed to file it doen a bit to fit but I can't remember the exact details.
Posted : 03/02/2020 7:17 pm
I've managed to make a shim for it, so that it slots into the end of the bar, yet is protected to some extent. Hopefully this will do the job.
Posted : 04/02/2020 11:40 am
