...well?
it's the lightest one that has all the tools [u]you[/u] need on it...
a 5mm allen key with the other end beaten flat to make a tyre lever?
SKS microtool. 37g . Tyre levers that work, three allan keys, a cross screwdriver and a spoke key. Plus room for Topeak flypaper patches and sandpaper. Don't over tighten or the weld will fail. Used it on Sunday to adjust a seatpost height. Note that this is placing emphasis on [b]lightweight[/b]
Somone ACTUALLY worries about the weight of their multitool. How very odd.
I presume you have a big steaming pre-ride dump and ride naked to save those vital grams? 🙄
It doesn't have to be the lightest, just something small compact and appropriate for a shirt pocket.
not odd at all, if your a roadie and carry these in your jersey pocket then you don't want a heavy multi-tool slapping about.
[url= http://www.cyclesurgery.com/birzman-feexman-eser-5-function-multi-tool/multi-tools/bikes-components-bikewear/fcp-product/46623 ]Picked up one of these for a fiver at the Surgery the other day[/url]
Impulse buy, but pretty impressive. I [i]think[/i] it's basically a debadged Lezyne.
That looks good CFH and I know its only a fiver, but I've £30 each of CRC and wiggle vouchers to spend.....
Lezyne you say.... hmmm
I have a Topeak Mini 9 Pro Carbon for road duties. 73g, a bunch of good quality allen keys, philips driver, and a couple of tyre levers. Very solid. All in a tiny wee package with a neat neoprene sleeve. Really very nice.
Rockplough - no chain tool....
This is true. If you want one with a chain tool though, you're really out of the 'lightweight' realm. If weight is an issue you'd probably be better carrying something like the Mini 9, plus a separate wee chain tool.
Cb with the chain tool though I don't gaf really I need one it goes in.
Edit# i is not a pro
the one your mate carries, so your pockets are full of cake.
I carry a Lezyne one but even then I still have a separate small park chain tool and normal 5mm allen key as I want a decent chain tool on the rare occurrences I need one and the stubby multi-tool 5mm doesn't reach a couple of the bolts on the bike.
http://www.chainreactioncycles.com/Models.aspx?ModelID=2924
Topeak chain tool with 5/6mm allen key plus a Leatherman squirt for scredrivers/pliers etc
CFH - That looks good, i'll behaving one of those. Thanking you.
For the second this this week
In 25 years of roadbiking, I've never had the need for a chain tool.
I just carry a Lezyne caddy pack with inflator, spare cartridge, lezyne pucture kit, spare tube, 2 Parktool tyre levers and 4, 5 and 6mm allen keys.
I've told you before, you dont have a multi tool on a road bike.m
All you need is allan keys, usualy just 3, and a chain tool
Lucky you, I've broken 3 road chains that I can recall. The first time I didn't have a chain tool. I now carry one!
Topeak Hexus for me, not light, but has everything I want and doesn't fall apart.
I probably break one or two mtb chains every year but never a roadie one... They just never seem to get worn to the same degree.
Watch this, I'll snap one next ride out!!!
jimmers - MemberLezyne V10 does the trick for me. Lightweight and not silly money.
My money's going here unless anyone convinces me otherwise....
Lezyne SV10 which is tiny, I think its a stainless version of a v10.
I don't see the point of doing that when you can have all that in a very small multi tool.
3 allan keys and a chain tool would weight much the same as the tool I carry anyway.
So come on then K 57
What are you anticipating you are going to fix when out on your road bike ?
I have a cheap one I got with a bike mag. Light and does the job.
Probably the same things you anticipate you're going to fix when you take your 3 allan keys and a chain tool.
+1 for Lezyne V10
I'm in a quandary now over the v10 and sv10 *drums fingers*
I've also got one of those Lezyne multi tools mainly because it fits in the Lezyne bike wallet which is a great piece of kit. Can't fault either really.
I use a Topeak Hexus, because the difference in weight is irrelevant and because getting caught out without the tool I want because I decided to save 2 grams would be annoying. Once you've got 3 allen keys and a chain tool, there's no real saving over a multitool.
And I don't worry about the tiny increase in size, because it lives in a saddlebag, along with all the other things I don't want sticking into my back.
A slight aside but I've recently upgraded to a 10spd road bike. How do you fix a 10spd chain? My procedure for a 9spd always involved removing the broken bits and shoving in a sram powerlink. Does the same apply for a 10speed.... (I know I could look this up but the thread got we wondering)
If he's anything like myself and folk I ride with, it could be anything from adjusting a front or rear mech thats rubbing (screwdriver), truing a wheel after a crash (spoke keys), adjusting rubbing break pads (torx), removing a tyre (tyre lever), on top of all the other things that use allen keys.
Yes that ^^. Fwiw I'm trying to find a size comparison for a v10 vs an sv10 vs an object I know the size of - anyone got any suggestions?
I say don't try and be a weightweenie with tools, get good ones...
456and8mm hex
miniparktool chain tool with spare quicklinks - knocking the pin out isn't a problem but trying to get a new pin in when you're outside getting cold not thinking straight...
3 tyrelevers
pump and tubes in the jersey pocket
you probably won't need the screwdrivers if your gears are working properly but can't hurt if you have one
Lezyne V10 is what I use but have found that chain tool is a almost useless.
Was looking for a suitable replacement reading this.
Crank Brothers 17. Best quality multi tool I've ever, ever had. Fact.
